error with make test
Umberto Nicoletti
unicoletti at PROMETEO.IT
Mon Feb 14 10:04:20 EST 2005
Do you have libmapscript.so in mapscript/java?
Can you run ldd -r libmapscript.so and post the results?
Umberto
On Mon, 2005-02-14 at 16:52 +0200, temiz wrote:
> hello
> after compiling mapscript with java,
> make test gives:
> bash-2.05b$ make test
> javac -classpath ./:examples/:./mapscript.jar -d examples/ examples/*.java
> java -classpath ./:examples/:./mapscript.jar -Djava.library.path=.
> DumpShp ../../tests/point.shp
> java.lang.UnsatisfiedLinkError:
> /usr/local/mapserver-4.4.1/mapscript/java/libmapscript.so:
> /usr/local/mapserver-4.4.1/mapscript/java/libmapscript.so: undefined
> symbol: gdImageGifPtr
> make: *** [test] Error 255
> could you tell me what the problem is
> regards
> Ahmet Temiz
> ______________________________________
> XamimeLT - installed on mailserver for domain @deprem.gov.tr
> Queries to: postmaster at deprem.gov.tr
> The views and opinions expressed in this e-mail message are the sender's own
> and do not necessarily represent the views and the opinions of Earthquake Research Dept.
> of General Directorate of Disaster Affairs.
> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
Umberto Nicoletti <unicoletti at prometeo.it>
Prometeo SRL
