Mapserver Error Code: 33
Frank Warmerdam
fwarmerdam at GMAIL.COM
Wed Feb 16 21:04:24 EST 2005
On Wed, 16 Feb 2005 13:46:11 -0800, pw <p.willis at telus.net> wrote:
> Hello,
> I get the following error from mapserver:
> msProcessProjection(): Projection library error. no system list, errno: 33
> What is error 33?
Peter,
Looking it up in /usr/include/asm/errno.h, it seems that error 33 is
EDOM (Math argument out of domain of func). Any of the errors above
0 are supposed to be system errno values.
> The map I am trying to render is a lambert conformal conic
> above 60 degrees latitude.
> Do proj4 or mapserver have problems if the map traverses the
> pole in lambert C.C. or Lambert equal area?
I am suspecting some sort of numerical problem related to the pole, or
your parameters.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
