help style->set(size,'size') ms-4.1.1
Daniel Lagos dlagos at FDCCONSULT.COM
Mon Feb 21 12:01:04 EST 2005
Thank you Bart,
comment out SYMBOLSCALE resolve the problem.
I can`t to see the ligth.
Thank you again.
Daniel  A. Lagos  H.
dlagos at fdcconsult.com
Santiago, Chile.
----- Original Message -----
To: "Daniel Lagos" <dlagos at fdcconsult.com>
Sent: Monday, February 21, 2005 11:30 AM
Subject: Re: [UMN_MAPSERVER-USERS] help style->set(size,'size') ms-4.1.1
> What happens if you comment out SYMBOLSCALE?
> # SYMBOLSCALE 20000
> Bart
> > Hi Bart,
> > From: <bartvde at xs4all.nl>
> > To: "Daniel Lagos" <dlagos at FDCCONSULT.COM>
> > Sent: Monday, February 21, 2005 10:13 AM
> >> Hi Daniel,
> >> is it a typo in your e-mail or do you have getclass with lowercase c in
> >> your script? It should be getClass.
> >> $clase = $layer->getClass(0);
> > Yes, error in my e-mail:
> >> Is there anything in your php error log? What happens if you save your
> >> MAP
> >> file after the symbol size change, what's in there?
> > No errors in php. I save my Map after the symbol size change and it
says:
> > LAYER
> >     NAME "clientes"
> >     SIZEUNITS PIXELS
> >     STATUS OFF
> >     SYMBOLSCALE 20000
> >     TEMPLATE "void"
> >     TOLERANCE 10
> >     TOLERANCEUNITS PIXELS
> >     TYPE POINT
> >     UNITS METERS
> >     DATA "Geodatos/clientes"
> >     CLASS
> >         NAME "cliente"
> >         LABEL
> >             SIZE MEDIUM
> >             TYPE BITMAP
> >             BUFFER 0
> >             COLOR 127 0 0
> >             FORCE FALSE
> >             MINDISTANCE -1
> >             MINFEATURESIZE -1
> >             OFFSET 0 0
> >             OUTLINECOLOR 255 255 255
> >             PARTIALS TRUE
> >             POSITION AUTO
> >       END
> >       METADATA
> >       END
> >       STYLE
> >           COLOR 255 0 0
> >           MAXSIZE 20
> >           MINSIZE 8
> >           OUTLINECOLOR 0 0 0
> >           SIZE 20
> >           SYMBOL "industria"
> >       END
> >       TEXT ([nombre] - [sucursal])
> >     END
> >   END
> > Look, the size in the simbol style is 20.
> > Thank's for helping.
