PHP/Mapscript Crash...
c p cplists at GMAIL.COM
Wed Feb 23 18:08:59 EST 2005
All,
I'm hoping someone here can help or can point me to a more appropriate
forum.  I've been having problems getting the samples that ship with
Chameleon v2.0 fully functional.  When I attempt to view one of the
sample maps I'm getting a segmentation fault:
==> error_log <==
[Wed Feb 23 15:59:59 2005] [notice] child pid 18222 exit signal
Segmentation fault (11)
By enabling/disabling different layers I was able to narrow the
problem down to the popplace layer and specifically the FONT, TYPE &
SIZE tags (which specify a truetype font) inside the LABEL definition.
 Commenting out these three tags result in the layer displaying
(albeit with the default bitmap font).  Although I've narrowed what
triggers the crash I still have no idea how to rectify the problem.
I'm further puzzled by the fact that when I use shp2img to render the
map it works fine which seems to suggest the problem is specific to
the php/mapscript module?
I'm running Fedora Core 2 & Mapserver v4.4.1 using the RPMs hosted at
the Mapping Hacks website (http://mappinghacks.com/rpm/).  I've
attached the chameleon.map file in case that helps.
Any help would be appreciated.
Thanks,
Corey
Type: application/text
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050223/4884a0a5/chameleon.bin
