IIS Config problem
Ed McNierney
ed at TOPOZONE.COM
Fri Feb 25 09:53:10 EST 2005
V P -
The error message you're getting seems to mean just what it says - that
layer has two NAME statements, and it can't have two names.
I'm not familiar with the sample data you're using, but over the recent
past MapServer has seen some syntax changes in the map file format, and
has become stricter in some senses about enforcing the rules. It sounds
like you're using an older example with newer code and running into
trouble.
You can comment out the second NAME field with an octathorpe (#) and see
where that gets you. If your application complains that it can't find a
layer named "cities", then switch and comment out the first one instead.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of V P
Sent: Friday, February 25, 2005 9:29 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] IIS Config problem
I don't think it had anything to do with the dll's. But I could be
wrong. I check the .map file.. line 381-ish.. I included the whole
portion of this 'class'"?". I put some asterics next to it. I don't know
what it's asking for. I even tried commenting it out. The url seemed
fine. I'm clueless...will keep trying though. Hope someone can help.
LAYER
NAME mcd90py2_anno
*** NAME cities
TYPE ANNOTATION
DATA mcd90py2
STATUS OFF
LABELITEM "city_name"
CLASSITEM "city_name"
LABELMAXSCALE 500000
CLASS
EXPRESSION /./
COLOR -1 -1 -1
LABEL
COLOR 0 0 0
SHADOWCOLOR 218 218 218
SHADOWSIZE 2 2
TYPE BITMAP
SIZE MEDIUM
POSITION CC
PARTIALS FALSE
BUFFER 2
END
END
METADATA
WMS_TITLE "Minor Civil Divisions"
WMS_ABSTRACT "Minor civil divisions for Itasca County. (annotation
only)"
WMS_SRS "EPSG:26915"
END
END
