PHP/Mapscript Crash...
Benoît Toutain
bf.toutain at FREE.FR
Fri Feb 25 10:57:41 EST 2005
Hi Corey,
perhaps the name of your library file is libgd.so or something like
that.... or your problem does not come from conflicts between two GD
libraries. Have you got a GD section when you make a <?php phpinfo(); ?> ?
Benoît
Corey Puffalt a écrit :
>My php.ini doesn't appear to have an extension=gd.so line... nor do
>any of the files in php.d/* do anyone know how to disable the gd
>extension with the stock FC2 rpms?
>Thanks,
>Corey
>On Fri, 25 Feb 2005 09:22:59 +0100, Benoît Toutain <bf.toutain at free.fr> wrote:
>>I commented the extension=gd.so line in my php.ini and restarted apache
>>and now it works.
>>No more crash for me too :-)
>>Thanks a lot
>>Best regards
>>Benoît
>>Constantin Cristian a écrit :
>>>I got the same problem, I googled for some answers:
>>>>Use phpinfo() to see if PHP has GD enabled, if it does then either
>>>>disable the PHP GD extension or make sure that both PHP and MapScript
>>>>use the same GD version. Also make sure that there is only one copy
>>>>of libgd.so and of the GD headers on your system.
>>>So I rebuilt my php installation and this time I used the gd that used to
>>>build mapscript rather then the bundled php gd
>>>and surprise... it doesn't crash anymore.
>>>----- Original Message -----
>>>From: "c p" <cplists at GMAIL.COM>
>>>To: <MAPSERVER-USERS at LISTS.UMN.EDU>
>>>Sent: Thursday, February 24, 2005 7:47 PM
>>>Subject: Re: [UMN_MAPSERVER-USERS] PHP/Mapscript Crash...
>>>Benoit,
>>>Well at least there's someone else to share my pain. :P After doing
>>>some more reading today I realized I wasn't running php as a cgi but
>>>as an apache DSO so I thought that must be my problem. Is it still
>>>true that PHP/Mapscript v4.4.1 still must be run as a cgi? Anyway, I
>>>reconfigured Apache to call php as a cgi but that did not resolve the
>>>crash. :(
>>>Regards,
>>>Corey
>>>On Thu, 24 Feb 2005 13:54:54 +0100, Benoît Toutain <bf.toutain at free.fr>
>>>wrote:
>>>>Hi Corey,
>>>>I have the same pb as you.
>>>>Here is my configuration obtained with <?php
>>>>dl('php_mapscript.so');phpinfo(); ?>
>>>>MapServer version 4.2.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SWF
>>>>SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>>>>SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=POSTGIS
>>>>INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>>>>($Revision: 1.194.2.6 $ $Date: 2004/08/25 16:27:43 $)
>>>>Is not there compatibity problems with freetype libraray and another
>>>>one ?
>>>>Hope everybody can show us the right way ;-)
>>>>Best regards,
>>>>Benoît
>>>>c p a écrit :
>>>>>All,
>>>>>I'm hoping someone here can help or can point me to a more appropriate
>>>>>forum. I've been having problems getting the samples that ship with
>>>>>Chameleon v2.0 fully functional. When I attempt to view one of the
>>>>>sample maps I'm getting a segmentation fault:
>>>>>==> error_log <==
>>>>>[Wed Feb 23 15:59:59 2005] [notice] child pid 18222 exit signal
>>>>>Segmentation fault (11)
>>>>>By enabling/disabling different layers I was able to narrow the
>>>>>problem down to the popplace layer and specifically the FONT, TYPE &
>>>>>SIZE tags (which specify a truetype font) inside the LABEL definition.
>>>>>Commenting out these three tags result in the layer displaying
>>>>>(albeit with the default bitmap font). Although I've narrowed what
>>>>>triggers the crash I still have no idea how to rectify the problem.
>>>>>I'm further puzzled by the fact that when I use shp2img to render the
>>>>>map it works fine which seems to suggest the problem is specific to
>>>>>the php/mapscript module?
>>>>>I'm running Fedora Core 2 & Mapserver v4.4.1 using the RPMs hosted at
>>>>>the Mapping Hacks website (http://mappinghacks.com/rpm/). I've
>>>>>attached the chameleon.map file in case that helps.
>>>>>Any help would be appreciated.
>>>>>Thanks,
>>>>>Corey
