PHP/Mapscript Crash...
Corey Puffalt cplists at GMAIL.COM
Fri Feb 25 10:47:17 EST 2005
My php.ini doesn't appear to have an extension=gd.so line... nor do
any of the files in php.d/* do anyone know how to disable the gd
extension with the stock FC2 rpms?
Thanks,
Corey
On Fri, 25 Feb 2005 09:22:59 +0100, Benoît Toutain <bf.toutain at free.fr> wrote:
> I commented the extension=gd.so line in my php.ini and restarted apache
> and now it works.
> No more crash for me too :-)
> Thanks a lot
> Best regards
> Benoît
> Constantin Cristian a écrit :
> > I got the same problem, I googled for some answers:
> >> Use phpinfo() to see if PHP has GD enabled, if it does then either
> >> disable the PHP GD extension or make sure that both PHP and MapScript
> >> use the same GD version.  Also make sure that there is only one copy
> >> of libgd.so and of the GD headers on your system.
> > So I rebuilt my php installation and this time I used the gd that used to
> > build mapscript rather then the bundled php gd
> > and surprise... it doesn't crash anymore.
> > ----- Original Message -----
> > From: "c p" <cplists at GMAIL.COM>
> > To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> > Sent: Thursday, February 24, 2005 7:47 PM
> > Subject: Re: [UMN_MAPSERVER-USERS] PHP/Mapscript Crash...
> > Benoit,
> > Well at least there's someone else to share my pain. :P  After doing
> > some more reading today I realized I wasn't running php as a cgi but
> > as an apache DSO so I thought that must be my problem.  Is it still
> > true that PHP/Mapscript v4.4.1 still must be run as a cgi?  Anyway, I
> > reconfigured Apache to call php as a cgi but that did not resolve the
> > crash. :(
> > Regards,
> > Corey
> > On Thu, 24 Feb 2005 13:54:54 +0100, Benoît Toutain <bf.toutain at free.fr>
> > wrote:
> >> Hi Corey,
> >> I have the same pb as you.
> >> Here is my configuration obtained with <?php
> >> dl('php_mapscript.so');phpinfo(); ?>
> >> MapServer version 4.2.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SWF
> >> SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> >> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=POSTGIS
> >> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> >> ($Revision: 1.194.2.6 $ $Date: 2004/08/25 16:27:43 $)
> >> Is not there compatibity problems with freetype libraray and another
> >> one ?
> >> Hope everybody can show us the right way ;-)
> >> Best regards,
> >> Benoît
> >> c p a écrit :
> >> >All,
> >> >I'm hoping someone here can help or can point me to a more appropriate
> >> >forum.  I've been having problems getting the samples that ship with
> >> >Chameleon v2.0 fully functional.  When I attempt to view one of the
> >> >sample maps I'm getting a segmentation fault:
> >> >==> error_log <==
> >> >[Wed Feb 23 15:59:59 2005] [notice] child pid 18222 exit signal
> >> >Segmentation fault (11)
> >> >By enabling/disabling different layers I was able to narrow the
> >> >problem down to the popplace layer and specifically the FONT, TYPE &
> >> >SIZE tags (which specify a truetype font) inside the LABEL definition.
> >> > Commenting out these three tags result in the layer displaying
> >> >(albeit with the default bitmap font).  Although I've narrowed what
> >> >triggers the crash I still have no idea how to rectify the problem.
> >> >I'm further puzzled by the fact that when I use shp2img to render the
> >> >map it works fine which seems to suggest the problem is specific to
> >> >the php/mapscript module?
> >> >I'm running Fedora Core 2 & Mapserver v4.4.1 using the RPMs hosted at
> >> >the Mapping Hacks website (http://mappinghacks.com/rpm/).  I've
> >> >attached the chameleon.map file in case that helps.
> >> >Any help would be appreciated.
> >> >Thanks,
> >> >Corey
