php mapscript causes segfault, strace attatched
Cornelius Keller
ckeller at INFORMATIK.HU-BERLIN.DE
Sun Feb 27 17:51:27 EST 2005
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hello mapserver users,
after installing php-mapserver on my laptop (debian unstable) and having fast
successes adapting and modifying the chameleon examples, I tried to install
php_mapscript on my webserver. Now I am trying for a whole week to make it run
properly but everything I tried failed till now.
Since my server is a linux-vserver, I will do another posting to the linux
vserver list to see if there is an issue there later.
First, I tried to run the self compiled php_mapscript (with php regex) module in
the apache php module, but this crashed the apache while starting.
So I contiued to try the cgi version of php. With the cgi version of php, I
achieved to get an php_info that tells me that the mapscript extension is
loaded, anyway it causes a segmentation fault when executing pages wich are
using mpascript.
I updated the web server so that it uses about the same php version and libs as
my laptop but the problem stays.
I am a bit desprate now, I tried all I can do but diving in to the mapserver c-code.
I pruduced a stactrace with the calling
strace /usr/lib/cgi-bin/php4 sample_basic_plainbuttons.phtml 2> strace.txt
I'll send it with this email, maybe one of you more advanced mapserver users or
devellopers can give me a hint what might be the problem.
If I can provide any information to make the issue more clear to you please ask me.
Thanks in advance for your time
greetings form berlin, germany
Cornelius Keller
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.0 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iQEVAwUBQiJO75FbnvyehKdrAQI9dggAgnvO7ydjkijB2UdKmEvjjH+QvCPV2RSb
kBFHv7vD7yne447/3ePFkfyin4rKYe+PVACtLei2M0Rh40+hfUuv0p+Z0Z07D6gP
qnsh1sycwNACGmowNciGPRgS0A1qPC0BEO2cUrOnudPbrL5bjT1lTIw1D+ubJngf
Az1EfpCs+rgoOlWxNYyI+lfGPXDVx43dYfQ+ZHoqPcEKQMbp7EQV12q3CnjhabuE
Zqa0yCI26FXpkHz85nygRrIbfmvqYzkNJ9800esuDjXjlqr9+4mG5Z5sMP2yUw30
Qn85PxKnLUlFrT/QfcQTOVzWyyqB43020hkCQcXXAJMwxtjcopx4qA==
=jG1b
-----END PGP SIGNATURE-----
execve("/usr/lib/cgi-bin/php4", ["/usr/lib/cgi-bin/php4", "sample_basic_plainbuttons.phtml"], [/* 15 vars */]) = 0
uname({sys="Linux", node="vserver745", ...}) = 0
brk(0) = 0x8317f4c
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40017000
access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory)
open("/etc/ld.so.preload", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=21296, ...}) = 0
old_mmap(NULL, 21296, PROT_READ, MAP_PRIVATE, 3, 0) = 0x40018000
close(3) = 0
open("/lib/libcrypt.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\0\n\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=18780, ...}) = 0
old_mmap(NULL, 181596, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4001e000
old_mmap(0x40023000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x4000) = 0x40023000
old_mmap(0x40024000, 157020, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40024000
close(3) = 0
open("/lib/libnsl.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0000<\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=73528, ...}) = 0
old_mmap(NULL, 84864, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4004b000
old_mmap(0x4005d000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x11000) = 0x4005d000
old_mmap(0x4005e000, 7040, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x4005e000
close(3) = 0
open("/usr/lib/libexpat.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\260\"\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=129972, ...}) = 0
old_mmap(NULL, 128880, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40060000
old_mmap(0x4007d000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1d000) = 0x4007d000
close(3) = 0
open("/usr/lib/libpcre.so.3", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\20\r\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=63992, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40080000
old_mmap(NULL, 62960, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40081000
old_mmap(0x40090000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xf000) = 0x40090000
close(3) = 0
open("/usr/lib/libdb-4.2.so", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0000\205"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=876584, ...}) = 0
old_mmap(NULL, 876124, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40091000
old_mmap(0x40165000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xd4000) = 0x40165000
close(3) = 0
open("/usr/lib/libbz2.so.1.0", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0000\22\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=62048, ...}) = 0
old_mmap(NULL, 61012, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40167000
old_mmap(0x40175000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xe000) = 0x40175000
close(3) = 0
open("/usr/lib/libz.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\200\27"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=67468, ...}) = 0
old_mmap(NULL, 70528, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40176000
old_mmap(0x40187000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x10000) = 0x40187000
close(3) = 0
open("/usr/lib/i686/cmov/libssl.so.0.9.7", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\0\205\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=198576, ...}) = 0
old_mmap(NULL, 199344, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40188000
old_mmap(0x401b6000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x2e000) = 0x401b6000
close(3) = 0
open("/lib/libresolv.so.2", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\240)\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=64924, ...}) = 0
old_mmap(NULL, 73640, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x401b9000
old_mmap(0x401c8000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xf000) = 0x401c8000
old_mmap(0x401c9000, 8104, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x401c9000
close(3) = 0
open("/lib/libm.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0 at 5\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=134464, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x401cb000
old_mmap(NULL, 136944, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x401cc000
old_mmap(0x401ed000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x20000) = 0x401ed000
close(3) = 0
open("/lib/libdl.so.2", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0p\34\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=9872, ...}) = 0
old_mmap(NULL, 8632, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x401ee000
old_mmap(0x401f0000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x2000) = 0x401f0000
close(3) = 0
open("/lib/libc.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\200^\1"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=1244016, ...}) = 0
old_mmap(NULL, 1254180, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x401f1000
old_mmap(0x40319000, 32768, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x127000) = 0x40319000
old_mmap(0x40321000, 8996, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40321000
close(3) = 0
open("/usr/lib/i686/cmov/libcrypto.so.0.9.7", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0p\300\2"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=1029672, ...}) = 0
old_mmap(NULL, 1043608, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40324000
old_mmap(0x4040e000, 73728, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xea000) = 0x4040e000
old_mmap(0x40420000, 11416, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40420000
close(3) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40423000
munmap(0x40018000, 21296) = 0
brk(0) = 0x8317f4c
brk(0x8338f4c) = 0x8338f4c
brk(0) = 0x8338f4c
brk(0x8339000) = 0x8339000
rt_sigaction(SIGPIPE, NULL, {SIG_DFL}, 8) = 0
rt_sigaction(SIGPIPE, {0x817f9a0, [], SA_RESTORER, 0x4021a678}, NULL, 8) = 0
rt_sigaction(SIGUSR1, NULL, {SIG_DFL}, 8) = 0
rt_sigaction(SIGUSR1, {0x817f990, [], SA_RESTORER, 0x4021a678}, NULL, 8) = 0
getpeername(0, 0xbffffab0, [112]) = -1 ENOTSOCK (Socket operation on non-socket)
rt_sigaction(SIGPIPE, {SIG_IGN}, {0x817f9a0, [], SA_RESTORER, 0x4021a678}, 8) = 0
open("/etc/localtime", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=837, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40018000
read(3, "TZif\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\10\0\0\0\10"..., 4096) = 837
close(3) = 0
munmap(0x40018000, 4096) = 0
open("./php-cgi-fcgi.ini", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/cgi-bin//php-cgi-fcgi.ini", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/etc/php4/cgi/php-cgi-fcgi.ini", O_RDONLY) = -1 ENOENT (No such file or directory)
open("./php.ini", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/cgi-bin//php.ini", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/etc/php4/cgi/php.ini", O_RDONLY) = 3
getcwd("/home/msapps/chameleon/samples_bln/htdocs", 4096) = 42
lstat64("/etc", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat64("/etc/php4", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat64("/etc/php4/cgi", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat64("/etc/php4/cgi/php.ini", {st_mode=S_IFREG|0644, st_size=26700, ...}) = 0
fstat64(3, {st_mode=S_IFREG|0644, st_size=26700, ...}) = 0
read(3, "[PHP]\n\n;;;;;;;;;;;\n; WARNING ;\n;"..., 8192) = 8192
read(3, "ime notices (these are warnings "..., 8192) = 8192
read(3, "; These configuration directives"..., 8192) = 8192
read(3, " want\n; error_reporting(0) aroun"..., 8192) = 2124
read(3, "", 4096) = 0
read(3, "", 8192) = 0
close(3) = 0
brk(0) = 0x8339000
brk(0x835a000) = 0x835a000
open("/etc/nsswitch.conf", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=465, ...}) = 0
read(3, "# /etc/nsswitch.conf\n#\n# Example"..., 4096) = 465
close(3) = 0
close(3) = 0
open("/lib/tls/i686/mmx/cmov/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/i686/mmx/cmov", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/lib/tls/i686/mmx/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/i686/mmx", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/lib/tls/i686/cmov/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/i686/cmov", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/lib/tls/i686/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/i686", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/lib/tls/mmx/cmov/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/mmx/cmov", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/lib/tls/mmx/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/mmx", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/lib/tls/cmov/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/tls/cmov", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/lib/tls/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/tls", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/lib/i686/mmx/cmov/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/i686/mmx/cmov", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/lib/i686/mmx/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/i686/mmx", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/lib/i686/cmov/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/i686/cmov", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/lib/i686/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/i686", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/lib/mmx/cmov/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/mmx/cmov", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/lib/mmx/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/mmx", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/lib/cmov/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib/cmov", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/lib/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/usr/lib/tls/i686/mmx/cmov/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/tls/i686/mmx/cmov", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/usr/lib/tls/i686/mmx/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/tls/i686/mmx", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/usr/lib/tls/i686/cmov/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/tls/i686/cmov", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/usr/lib/tls/i686/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/tls/i686", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/usr/lib/tls/mmx/cmov/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/tls/mmx/cmov", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/usr/lib/tls/mmx/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/tls/mmx", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/usr/lib/tls/cmov/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/tls/cmov", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/usr/lib/tls/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/tls", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/usr/lib/i686/mmx/cmov/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/i686/mmx/cmov", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/usr/lib/i686/mmx/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/i686/mmx", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/usr/lib/i686/cmov/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/i686/cmov", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/usr/lib/i686/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/i686", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open("/usr/lib/mmx/cmov/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/mmx/cmov", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/usr/lib/mmx/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/mmx", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/usr/lib/cmov/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/cmov", 0xbffff350) = -1 ENOENT (No such file or directory)
open("/usr/lib/libnss_db.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/lib", {st_mode=S_IFDIR|0755, st_size=12288, ...}) = 0
close(3) = 0
open("/lib/libnss_files.so.2", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\220\35"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=34520, ...}) = 0
old_mmap(NULL, 33720, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40424000
old_mmap(0x4042c000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x8000) = 0x4042c000
close(3) = 0
open("/etc/protocols", O_RDONLY) = 3
fcntl64(3, F_GETFD) = 0
fcntl64(3, F_SETFD, FD_CLOEXEC) = 0
fstat64(3, {st_mode=S_IFREG|0644, st_size=2478, ...}) = 0
read(3, "# Internet (IP) protocols\n#\n# Up"..., 4096) = 2478
close(3) = 0
close(3) = 0
open("/usr/share/misc/file/magic.mime", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=30429, ...}) = 0
read(3, "# Magic data for KMimeMagic (ori"..., 4096) = 4096
read(3, "audio/x-dec-basic\n>12\tlelong\t\t5\t"..., 4096) = 4096
read(3, " #!/usr/local/bin/ash applica"..., 4096) = 4096
read(3, "\\040\\0\t\tapplication/x-tar\tgnu\n\n0"..., 4096) = 4096
read(3, "p Format proposal\n# (best; not y"..., 4096) = 4096
read(3, "--------------------------------"..., 4096) = 4096
read(3, " 0x05\t\n#>8 leshort\t >0"..., 4096) = 4096
read(3, "#\n0\t\tstring\tMZ\n>24\t\tstring\t@\t\tap"..., 4096) = 1757
close(3) = 0
brk(0) = 0x835a000
brk(0x837b000) = 0x837b000
open("/usr/lib/php4/20020429/mysql.so", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\360-\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=44432, ...}) = 0
old_mmap(NULL, 47584, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4042d000
old_mmap(0x40438000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xa000) = 0x40438000
close(3) = 0
close(3) = 0
open("/usr/lib/libmysqlclient.so.10", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\210\200"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=214344, ...}) = 0
old_mmap(NULL, 213792, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40439000
old_mmap(0x40455000, 102400, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1c000) = 0x40455000
close(3) = 0
open("/usr/lib/php4/20020429/php_mapscript.so", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\220\220"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=998412, ...}) = 0
old_mmap(NULL, 912012, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4046e000
old_mmap(0x40547000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xd9000) = 0x40547000
old_mmap(0x4054c000, 2700, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x4054c000
close(3) = 0
close(3) = 0
open("/usr/lib/libcurl.so.2", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\320`\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=177800, ...}) = 0
old_mmap(NULL, 181340, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4054d000
old_mmap(0x40578000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x2a000) = 0x40578000
close(3) = 0
open("/usr/lib/libjpeg.so.62", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\300$\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=120952, ...}) = 0
old_mmap(NULL, 119916, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4057a000
old_mmap(0x40597000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1d000) = 0x40597000
close(3) = 0
open("/usr/lib/libfreetype.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\260\346"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=447212, ...}) = 0
old_mmap(NULL, 446176, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40598000
old_mmap(0x405fe000, 28672, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x66000) = 0x405fe000
close(3) = 0
open("/usr/lib/libpng12.so.0", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\220\\\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=147224, ...}) = 0
old_mmap(NULL, 150228, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40605000
old_mmap(0x40629000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x23000) = 0x40629000
close(3) = 0
open("/usr/lib/libgdal.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\260\37"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=3356768, ...}) = 0
old_mmap(NULL, 3709824, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4062a000
old_mmap(0x408e2000, 507904, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x2b8000) = 0x408e2000
old_mmap(0x4095e000, 351104, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x4095e000
close(3) = 0
open("/usr/lib/libproj.so.0", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\240`\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=217104, ...}) = 0
old_mmap(NULL, 216220, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x409b4000
old_mmap(0x409e7000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x33000) = 0x409e7000
close(3) = 0
open("/usr/lib/libgd.so.2", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\300S\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=236016, ...}) = 0
old_mmap(NULL, 321880, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x409e9000
old_mmap(0x40a04000, 131072, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1a000) = 0x40a04000
old_mmap(0x40a24000, 80216, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40a24000
close(3) = 0
open("/usr/lib/libstdc++.so.5", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\200\301"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=737816, ...}) = 0
old_mmap(NULL, 761536, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40a38000
old_mmap(0x40ad7000, 90112, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x9e000) = 0x40ad7000
old_mmap(0x40aed000, 20160, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40aed000
close(3) = 0
open("/lib/libgcc_s.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\20\30\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=32324, ...}) = 0
old_mmap(NULL, 35336, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40af2000
old_mmap(0x40afa000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x7000) = 0x40afa000
close(3) = 0
open("/usr/lib/libgeos.so.2", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\220?\4"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=902272, ...}) = 0
old_mmap(NULL, 906080, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40afb000
old_mmap(0x40bb9000, 126976, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xbd000) = 0x40bb9000
old_mmap(0x40bd8000, 864, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40bd8000
close(3) = 0
open("/usr/lib/libodbc.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\20<\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=488464, ...}) = 0
old_mmap(NULL, 487564, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40bd9000
old_mmap(0x40c4c000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x73000) = 0x40c4c000
old_mmap(0x40c50000, 140, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40c50000
close(3) = 0
open("/usr/lib/libxerces-c.so.21", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\204\351"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=2593344, ...}) = 0
old_mmap(NULL, 2600044, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40c51000
old_mmap(0x40e6d000, 385024, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x21b000) = 0x40e6d000
old_mmap(0x40ecb000, 3180, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40ecb000
close(3) = 0
open("/usr/lib/libjasper-1.701.so.1", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\0r\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=272196, ...}) = 0
old_mmap(NULL, 296892, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40ecc000
old_mmap(0x40f0c000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x40000) = 0x40f0c000
old_mmap(0x40f0f000, 22460, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40f0f000
close(3) = 0
open("/usr/lib/libmfhdf.so.4", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\0\\\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=133840, ...}) = 0
old_mmap(NULL, 137184, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40f15000
old_mmap(0x40f35000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x20000) = 0x40f35000
old_mmap(0x40f36000, 2016, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40f36000
close(3) = 0
open("/usr/lib/libdf.so.4", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0p\2\1\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=482928, ...}) = 0
old_mmap(NULL, 649164, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40f37000
old_mmap(0x40fab000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x74000) = 0x40fab000
old_mmap(0x40fad000, 165836, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40fad000
close(3) = 0
open("/usr/lib/libungif.so.4", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\340\25"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=28484, ...}) = 0
old_mmap(NULL, 31552, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40fd6000
old_mmap(0x40fdd000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x6000) = 0x40fdd000
close(3) = 0
open("/usr/lib/libtiff.so.4", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\0G\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=321744, ...}) = 0
old_mmap(NULL, 321696, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40fde000
old_mmap(0x4102b000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x4d000) = 0x4102b000
close(3) = 0
open("/usr/lib/libnetcdf.so.3", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\344g\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=141936, ...}) = 0
old_mmap(NULL, 141336, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4102d000
old_mmap(0x4104f000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x22000) = 0x4104f000
close(3) = 0
open("/usr/lib/libcfitsio.so.2", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\2400\1"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=1023664, ...}) = 0
old_mmap(NULL, 1497480, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x41050000
old_mmap(0x41148000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xf8000) = 0x41148000
old_mmap(0x4114a000, 473480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x4114a000
close(3) = 0
open("/lib/libpthread.so.0", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\340A\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=81127, ...}) = 0
old_mmap(NULL, 331716, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x411be000
old_mmap(0x411cb000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xc000) = 0x411cb000
old_mmap(0x411cd000, 270276, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x411cd000
close(3) = 0
open("/usr/lib/libpq.so.3", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\340W\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=110768, ...}) = 0
old_mmap(NULL, 109856, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4120f000
old_mmap(0x41229000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1a000) = 0x41229000
close(3) = 0
open("/usr/lib/libltdl.so.3", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0000\24\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=25004, ...}) = 0
old_mmap(NULL, 28116, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4122a000
old_mmap(0x41230000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x5000) = 0x41230000
close(3) = 0
open("/usr/lib/libkrb5.so.3", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\240\372"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=425800, ...}) = 0
old_mmap(NULL, 425224, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x41231000
old_mmap(0x41297000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x66000) = 0x41297000
close(3) = 0
open("/usr/lib/libk5crypto.so.3", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\2205\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=138664, ...}) = 0
old_mmap(NULL, 138688, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x41299000
old_mmap(0x412ba000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x21000) = 0x412ba000
close(3) = 0
open("/lib/libcom_err.so.2", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\230\n\0"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=5900, ...}) = 0
old_mmap(NULL, 8996, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x412bb000
old_mmap(0x412bd000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1000) = 0x412bd000
close(3) = 0
getrlimit(RLIMIT_STACK, {rlim_cur=RLIM_INFINITY, rlim_max=RLIM_INFINITY}) = 0
setrlimit(RLIMIT_STACK, {rlim_cur=2044*1024, rlim_max=RLIM_INFINITY}) = 0
getpid() = 19538
rt_sigaction(SIGRTMIN, {0x411c6030, [], SA_RESTORER, 0x4021a678}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {0x411c6080, [], SA_RESTORER, 0x4021a678}, NULL, 8) = 0
rt_sigaction(SIGRT_2, {0x411c6150, [], SA_RESTORER, 0x4021a678}, NULL, 8) = 0
rt_sigprocmask(SIG_BLOCK, [RTMIN], NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RT_1], NULL, 8) = 0
_sysctl({{CTL_KERN, KERN_VERSION}, 2, 0xbffff328, 35, (nil), 0}) = 0
getpid() = 19538
time(NULL) = 1109542424
brk(0) = 0x837b000
brk(0x839c000) = 0x839c000
open("/usr/lib/php4/20020429/dbase.so", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0p\35\0\000"..., 512) = 512
fstat64(3, {st_mode=S_IFREG|0644, st_size=22340, ...}) = 0
old_mmap(NULL, 21372, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40018000
old_mmap(0x4001d000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x5000) = 0x4001d000
close(3) = 0
setitimer(ITIMER_PROF, {it_interval={0, 0}, it_value={30, 0}}, NULL) = 0
rt_sigaction(SIGPROF, {0x411c97a0, [PROF], SA_RESTORER|SA_RESTART, 0x4021a678}, {SIG_DFL}, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [PROF], NULL, 8) = 0
gettimeofday({1109542424, 885007}, NULL) = 0
getpid() = 19538
open("sample_basic_plainbuttons.phtml", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0664, st_size=1228, ...}) = 0
lstat64("/home", {st_mode=S_IFDIR|S_ISGID|0775, st_size=4096, ...}) = 0
lstat64("/home/msapps", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat64("/home/msapps/chameleon", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat64("/home/msapps/chameleon/samples_bln", {st_mode=S_IFDIR|S_ISGID|0775, st_size=4096, ...}) = 0
lstat64("/home/msapps/chameleon/samples_bln/htdocs", {st_mode=S_IFDIR|S_ISGID|0775, st_size=4096, ...}) = 0
lstat64("/home/msapps/chameleon/samples_bln/htdocs/sample_basic_plainbuttons.phtml", {st_mode=S_IFREG|0664, st_size=1228, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x412be000
read(3, "<?php\n/*\n * this is a sample of "..., 4096) = 1228
_llseek(3, 0, [0], SEEK_SET) = 0
rt_sigaction(SIGPROF, {0x411c97a0, [PROF], SA_RESTORER|SA_RESTART, 0x4021a678}, {0x411c97a0, [PROF], SA_RESTORER|SA_RESTART, 0x4021a678}, 8) = 0
read(3, "<?php\n/*\n * this is a sample of "..., 8192) = 1228
close(3) = 0
munmap(0x412be000, 4096) = 0
lstat64("/home/msapps/chameleon/htdocs", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat64("/home/msapps/chameleon/htdocs/chameleon.php", {st_mode=S_IFREG|0644, st_size=54101, ...}) = 0
open("/home/msapps/chameleon/htdocs/chameleon.php", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=54101, ...}) = 0
lseek(3, 0, SEEK_CUR) = 0
lseek(3, 0, SEEK_SET) = 0
read(3, "<?php\n/**\n *\n * @project CWC"..., 8192) = 8192
read(3, "}\n else\n "..., 8192) = 8192
read(3, "= $this->mszTemplateName;\n\n "..., 8192) = 8192
brk(0) = 0x839c000
brk(0x83c0000) = 0x83c0000
read(3, ";\n \n $_SESSION[\'gs"..., 8192) = 8192
read(3, " * based on it\'s name. If mor"..., 8192) = 8192
read(3, "nal path if it is not web-visibl"..., 8192) = 8192
read(3, ";\n\n//\n// Define chameleon absolu"..., 8192) = 4949
brk(0) = 0x83c0000
brk(0x83ee000) = 0x83ee000
brk(0) = 0x83ee000
brk(0) = 0x83ee000
brk(0x83eb000) = 0x83eb000
brk(0) = 0x83eb000
brk(0) = 0x83eb000
brk(0) = 0x83eb000
brk(0x83e2000) = 0x83e2000
brk(0) = 0x83e2000
close(3) = 0
stat64("./HttpFormVars.php", 0xbfffa40c) = -1 ENOENT (No such file or directory)
stat64("/usr/share/php/HttpFormVars.php", 0xbfffa40c) = -1 ENOENT (No such file or directory)
stat64("/usr/share/pear/HttpFormVars.php", 0xbfffa40c) = -1 ENOENT (No such file or directory)
stat64("/home/msapps/chameleon/htdocs/HttpFormVars.php", {st_mode=S_IFREG|0644, st_size=3985, ...}) = 0
lstat64("/home/msapps/chameleon/htdocs/HttpFormVars.php", {st_mode=S_IFREG|0644, st_size=3985, ...}) = 0
open("/home/msapps/chameleon/htdocs/HttpFormVars.php", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=3985, ...}) = 0
read(3, "<?php\n/**\n *\n * @project CWC"..., 8192) = 3985
close(3) = 0
access("/home/msapps/chameleon/htdocs/../config/", F_OK) = 0
access("/home/msapps/chameleon/htdocs/../config//chameleon.xml", F_OK) = 0
access("/home/msapps/chameleon/htdocs/common/", F_OK) = 0
lstat64("/home/msapps/chameleon/htdocs/common", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat64("/home/msapps/chameleon/htdocs/common/logger", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat64("/home/msapps/chameleon/htdocs/common/logger/logfile.php", {st_mode=S_IFREG|0644, st_size=6331, ...}) = 0
open("/home/msapps/chameleon/htdocs/common/logger/logfile.php", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=6331, ...}) = 0
read(3, "<?php\n/**\n * LogFile Module\n * \n"..., 8192) = 6331
close(3) = 0
lstat64("/home/msapps/chameleon/htdocs/common/logger/error_manager.php", {st_mode=S_IFREG|0644, st_size=9026, ...}) = 0
open("/home/msapps/chameleon/htdocs/common/logger/error_manager.php", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=9026, ...}) = 0
read(3, "<?php\n/**\n * ErrorManager Module"..., 8192) = 8192
read(3, "= array(E_USER_ERROR, E_USER_WAR"..., 8192) = 834
close(3) = 0
lstat64("/home/msapps/chameleon/htdocs/common/logger/logger.php", {st_mode=S_IFREG|0644, st_size=9743, ...}) = 0
open("/home/msapps/chameleon/htdocs/common/logger/logger.php", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=9743, ...}) = 0
read(3, "<?php\n/**\n * Logger Module\n * \n "..., 8192) = 8192
read(3, " ob_start();\n prin"..., 8192) = 1551
close(3) = 0
lstat64("/home/msapps/chameleon/htdocs/common/appcontext", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat64("/home/msapps/chameleon/htdocs/common/appcontext/appcontext.php", {st_mode=S_IFREG|0644, st_size=17570, ...}) = 0
open("/home/msapps/chameleon/htdocs/common/appcontext/appcontext.php", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=17570, ...}) = 0
read(3, "<?php\n/**\n * AppContext is a uti"..., 8192) = 8192
brk(0) = 0x83e2000
brk(0x8409000) = 0x8409000
brk(0) = 0x8409000
brk(0) = 0x8409000
brk(0x8406000) = 0x8406000
brk(0) = 0x8406000
read(3, " "..., 8192) = 8192
read(3, "->szContextFile.\"</context-file>"..., 8192) = 1186
close(3) = 0
stat64("/home/msapps/chameleon/htdocs/common/", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
close(3) = 0
lstat64("/home/msapps/chameleon/htdocs/common/wrapper", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat64("/home/msapps/chameleon/htdocs/common/wrapper/map_session.php", {st_mode=S_IFREG|0644, st_size=50132, ...}) = 0
open("/home/msapps/chameleon/htdocs/common/wrapper/map_session.php", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=50132, ...}) = 0
read(3, "<?php\n/**\n * MapSession Module\n "..., 8192) = 8192
read(3, ") done\" );\n\n // return su"..., 8192) = 8192
read(3, "this->getInsertionIndexByType( $"..., 8192) = 8192
read(3, "the requested map file\n "..., 8192) = 8192
brk(0) = 0x8406000
brk(0x8428000) = 0x8428000
read(3, "s->error( ERR_FILE_IO, \"The temp"..., 8192) = 8192
read(3, " ($this->labelsizeitem != NOTSET"..., 8192) = 8192
brk(0) = 0x8428000
brk(0x8456000) = 0x8456000
brk(0) = 0x8456000
brk(0) = 0x8456000
brk(0x844c000) = 0x844c000
brk(0) = 0x844c000
read(3, " $oStyle->set(\"offsetx\", $this"..., 8192) = 980
close(3) = 0
lstat64("/home/msapps/chameleon/htdocs/common/mlt", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat64("/home/msapps/chameleon/htdocs/common/mlt/mlt.php", {st_mode=S_IFREG|0644, st_size=11756, ...}) = 0
open("/home/msapps/chameleon/htdocs/common/mlt/mlt.php", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=11756, ...}) = 0
read(3, "<?php\n/**\n * Multi-Lingual Trans"..., 8192) = 8192
read(3, "ms = array() )\n {\n $bR"..., 8192) = 3564
close(3) = 0
close(3) = 0
lstat64("/home/msapps/chameleon/htdocs/common/session", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat64("/home/msapps/chameleon/htdocs/common/session/session.php", {st_mode=S_IFREG|0644, st_size=16213, ...}) = 0
open("/home/msapps/chameleon/htdocs/common/session/session.php", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=16213, ...}) = 0
read(3, "<?php\n/**\n * DirectorySessionHan"..., 8192) = 8192
read(3, "arbageColectionCallBackFunction\'"..., 8192) = 8021
brk(0) = 0x844c000
brk(0x8479000) = 0x8479000
brk(0) = 0x8479000
brk(0) = 0x8479000
brk(0x846e000) = 0x846e000
brk(0) = 0x846e000
close(3) = 0
stat64("./widgets/ms_error.php", 0xbfffa40c) = -1 ENOENT (No such file or directory)
stat64("/usr/share/php/widgets/ms_error.php", 0xbfffa40c) = -1 ENOENT (No such file or directory)
stat64("/usr/share/pear/widgets/ms_error.php", 0xbfffa40c) = -1 ENOENT (No such file or directory)
stat64("/home/msapps/chameleon/htdocs/widgets/ms_error.php", {st_mode=S_IFREG|0644, st_size=4049, ...}) = 0
lstat64("/home/msapps/chameleon/htdocs/widgets", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat64("/home/msapps/chameleon/htdocs/widgets/ms_error.php", {st_mode=S_IFREG|0644, st_size=4049, ...}) = 0
open("/home/msapps/chameleon/htdocs/widgets/ms_error.php", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=4049, ...}) = 0
read(3, "<?php\n/**\n * generic mapserver e"..., 8192) = 4049
close(3) = 0
stat64("./widgets/ows.php", 0xbfffa40c) = -1 ENOENT (No such file or directory)
stat64("/usr/share/php/widgets/ows.php", 0xbfffa40c) = -1 ENOENT (No such file or directory)
stat64("/usr/share/pear/widgets/ows.php", 0xbfffa40c) = -1 ENOENT (No such file or directory)
stat64("/home/msapps/chameleon/htdocs/widgets/ows.php", {st_mode=S_IFREG|0644, st_size=6945, ...}) = 0
lstat64("/home/msapps/chameleon/htdocs/widgets/ows.php", {st_mode=S_IFREG|0644, st_size=6945, ...}) = 0
open("/home/msapps/chameleon/htdocs/widgets/ows.php", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=6945, ...}) = 0
read(3, "<?php\n/**\n *\n * @project Cha"..., 8192) = 6945
close(3) = 0
stat64("./ms_error.php", 0xbfffa24c) = -1 ENOENT (No such file or directory)
stat64("/usr/share/php/ms_error.php", 0xbfffa24c) = -1 ENOENT (No such file or directory)
stat64("/usr/share/pear/ms_error.php", 0xbfffa24c) = -1 ENOENT (No such file or directory)
close(3) = 0
access("/tmp", F_OK) = 0
access("/tmp", W_OK) = 0
nanosleep({0, 1000}, NULL) = 0
gettimeofday({1109542424, 948640}, NULL) = 0
access("/tmp/sess_42224618e79a0", F_OK) = -1 ENOENT (No such file or directory)
mkdir("/tmp/sess_42224618e79a0", 0777) = 0
access("/tmp/sess_42224618e79a0", F_OK) = 0
lstat64("/tmp", {st_mode=S_IFDIR|S_ISVTX|0777, st_size=4096, ...}) = 0
lstat64("/tmp/sess_42224618e79a0", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat64("/tmp/sess_42224618e79a0/session_file", 0xbfff787c) = -1 ENOENT (No such file or directory)
open("/tmp/sess_42224618e79a0/session_file", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/var/log/apache/php.log", O_WRONLY|O_APPEND|O_CREAT, 0666) = 3
fstat64(3, {st_mode=S_IFREG|0666, st_size=1, ...}) = 0
_llseek(3, 1, [1], SEEK_SET) = 0
time([1109542424]) = 1109542424
write(3, "[27-Feb-2005 23:13:44] PHP Notic"..., 138) = 138
close(3) = 0
fstat64(3, {st_mode=S_IFREG|0666, st_size=139, ...}) = 0
_llseek(3, 139, [139], SEEK_SET) = 0
write(3, "[27-Feb-2005 23:13:44] PHP Notic"..., 124) = 124
close(3) = 0
fstat64(3, {st_mode=S_IFREG|0666, st_size=263, ...}) = 0
_llseek(3, 263, [263], SEEK_SET) = 0
write(3, "[27-Feb-2005 23:13:44] PHP Notic"..., 126) = 126
close(3) = 0
fstat64(3, {st_mode=S_IFREG|0666, st_size=389, ...}) = 0
_llseek(3, 389, [389], SEEK_SET) = 0
write(3, "[27-Feb-2005 23:13:44] PHP Notic"..., 122) = 122
close(3) = 0
fstat64(3, {st_mode=S_IFREG|0666, st_size=511, ...}) = 0
_llseek(3, 511, [511], SEEK_SET) = 0
close(3) = 0
access("/home/msapps/chameleon/htdocs/../config/chameleon.xml", F_OK) = 0
lstat64("/home/msapps/chameleon/config", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat64("/home/msapps/chameleon/config/chameleon.xml", {st_mode=S_IFREG|0644, st_size=5074, ...}) = 0
open("/home/msapps/chameleon/config/chameleon.xml", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=5074, ...}) = 0
stat64("/home/msapps/chameleon/htdocs/../config/chameleon.xml", {st_mode=S_IFREG|0644, st_size=5074, ...}) = 0
read(3, "<app-context>\n <context-param"..., 8192) = 5074
close(3) = 0
brk(0) = 0x846e000
brk(0x848f000) = 0x848f000
open("/home/msapps/chameleon/htdocs/CWC2.dbf", O_RDONLY) = 3
read(3, "\3\4\n\r\6\0\0\0\201\0\26\2\0\0\0\0\0\0\0\0\0\0\0\0\0\0"..., 32) = 32
read(3, "KEY\0\0\0\0\0\0\0\0C\0\0\0\0\31\0\0\0\0\0\0\0\0\0\0\0\0"..., 32) = 32
read(3, "EN_CA\0\0\0\0\0\0C\0\0\0\0\376\0\0\0\0\0\0\0\0\0\0\0\0"..., 32) = 32
read(3, "FR_CA\0\0\0\0\0\0C\0\0\0\0\376\0\0\0\0\0\0\0\0\0\0\0\0"..., 32) = 32
read(3, "\r 0 FATAL", 32) = 32
lseek(3, 129, SEEK_SET) = 129
read(3, " 0 FATAL "..., 534) = 534
lseek(3, 663, SEEK_SET) = 663
read(3, " 1 ERROR:"..., 534) = 534
lseek(3, 1197, SEEK_SET) = 1197
read(3, " 2 ERROR:"..., 534) = 534
lseek(3, 1731, SEEK_SET) = 1731
read(3, " 3 ERROR:"..., 534) = 534
lseek(3, 2265, SEEK_SET) = 2265
read(3, " 4 ERROR:"..., 534) = 534
lseek(3, 2799, SEEK_SET) = 2799
read(3, " 5 WARNIN"..., 534) = 534
open("/home/msapps/chameleon/htdocs/common.dbf", O_RDONLY) = 4
lseek(4, 0, SEEK_SET) = 0
read(4, "\3\16\10\6\22\0\0\0\201\0\26\2\0\0\0\0\0\0\0\0\0\0\0\0"..., 32) = 32
read(4, "KEY\0\0\0\0\0\0\0\0C\1\0\0\0\31\0\0\0\0\0\0\0\0\0\0\0\0"..., 32) = 32
read(4, "EN_CA\0\0\0\0\0\0C\32\0\0\0\376\0\0\0\0\0\0\0\0\0\0\0\0"..., 32) = 32
read(4, "FR_CA\0\0\0\0\0\0C\30\1\0\0\376\0\0\0\0\0\0\0\0\0\0\0\0"..., 32) = 32
read(4, "\r Ok Ok ", 32) = 32
lseek(4, 129, SEEK_SET) = 129
read(4, " Ok Ok "..., 534) = 534
lseek(4, 663, SEEK_SET) = 663
read(4, " Cancel Cancel"..., 534) = 534
lseek(4, 1197, SEEK_SET) = 1197
read(4, " Apply Apply "..., 534) = 534
lseek(4, 1731, SEEK_SET) = 1731
read(4, " OkTip Apply "..., 534) = 534
lseek(4, 2265, SEEK_SET) = 2265
read(4, " CancelTip Cancel"..., 534) = 534
lseek(4, 2799, SEEK_SET) = 2799
read(4, " ApplyTip Apply "..., 534) = 534
lseek(4, 3333, SEEK_SET) = 3333
read(4, " Width Width "..., 534) = 534
lseek(4, 3867, SEEK_SET) = 3867
read(4, " Height Height"..., 534) = 534
lseek(4, 4401, SEEK_SET) = 4401
read(4, " Zoom Zoom "..., 534) = 534
lseek(4, 4935, SEEK_SET) = 4935
read(4, " Min Min "..., 534) = 534
lseek(4, 5469, SEEK_SET) = 5469
read(4, " Max Max "..., 534) = 534
lseek(4, 6003, SEEK_SET) = 6003
read(4, " Close Close "..., 534) = 534
lseek(4, 6537, SEEK_SET) = 6537
read(4, " CloseTip Close "..., 534) = 534
lseek(4, 7071, SEEK_SET) = 7071
read(4, " ZoomRectTip Zoom t"..., 534) = 534
lseek(4, 7605, SEEK_SET) = 7605
read(4, " ZoomPointTip Zoom t"..., 534) = 534
lseek(4, 8139, SEEK_SET) = 8139
read(4, " CBNotSet ERROR:"..., 534) = 534
lseek(4, 8673, SEEK_SET) = 8673
read(4, " ErrInvExt ERROR:"..., 534) = 534
lseek(4, 9207, SEEK_SET) = 9207
read(4, " Spinner ../../"..., 534) = 534
setitimer(ITIMER_PROF, {it_interval={0, 0}, it_value={0, 0}}, NULL) = 0
setitimer(ITIMER_PROF, {it_interval={0, 0}, it_value={120, 0}}, NULL) = 0
access("/home/msapps/chameleon/samples_bln/map/brb.map", F_OK) = 0
stat64("/home/msapps/chameleon/samples_bln/map", {st_mode=S_IFDIR|S_ISGID|0775, st_size=4096, ...}) = 0
--- SIGSEGV (Segmentation fault) @ 0 (0) ---
+++ killed by SIGSEGV +++
