Tiger Line Data
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon Feb 28 23:28:34 EST 2005
Hermawan,
See comments below
Hermawan Sutantio wrote:
> Hi all.
> I might need some more help.
> Based on the recommendation that Stephen gave, I tried to compile 2
> counties
> in michigan using the commands recommended. Below is the michigan.map file
> that i generated. Please help me review them whether anything is wrong.
> Thanks.
You need to start your mapfile with:
MAP
> FONTSET "C:\MS4W\apps\maplab-2.2\tutorial\etc\fonts.list"
> # Start of map file
> NAME Michigan
> STATUS ON
> SIZE 500 500
> UNITS DD
> EXTENT -84.133748 42.072069 -83.539394 42.4345936
> SHAPEPATH "C:\cygwin\hcslmap\data\tiger"
> IMAGECOLOR 255 255 255
> # Start of web interface definition
> WEB
> # On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the root
> # of the drive where the .MAP file resides.
> IMAGEPATH "C/ms4w/tmp/ms_tmp/"
Are you missing a ":" as in "C:"
> IMAGEURL "/ms_tmp/"
> # LOG "/tmp/gmap.log"
> TEMPLATE demo.html
> METADATA
> "TITLE" "Michigan Test Demo"
> END
> END
> # Start of legend
> LEGEND
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> STATUS OFF
> END
> # Start of scalebar
> SCALEBAR
> LABEL
> COLOR 0 0 0
> SIZE SMALL
> END
> SIZE 150 4
> COLOR 255 255 255
> BACKGROUNDCOLOR 0 0 0
> OUTLINECOLOR 0 0 0
> UNITS miles
> INTERVALS 3
> STATUS ON
> END
> # Querymap settings
> # Style is one of NORMAL, HILITE, or SELECTED
> QUERYMAP
> STYLE HILITE
> COLOR 255 0 0
> END
> # Start of layer definitions
> LAYER
> NAME Street_Map
> TYPE LINE
> STATUS ON
STATUS ON says that you can display the layer, but not that it WILL be
desplayed. Until you understand this, I would use
STATUS DEFAULT
> TILEINDEX "C:\cygwin\hcslmap\data\tiger\mich-tile.shp"
> CLASS
> NAME "Street_Map"
You probably need to specify the color and style of the line. Try
COLOR 0 0 0 # black
SIZE 1 # one pixel width
> END
> END # Layer
> END #map
> Herman Teo wrote:
>> Hi Stephen,
>> Thanks for the tip. I'm now scouring through the previous list
>> messages for 'tile' commands. There is not much of that going on. Is
>> there a sample code where I might be able to learn how I should
>> proceed with shape tiling and a sniff of a LAYER...END code in the
>> map file. Also, is any of these tiger line on sale somewhere so that
>> I might not have to download 300k files as you said. Thanks a lot.
> Herman,
> There are two different tiling commands:
> 1) tile4ms which is distributed as part of the mapserver source and is
> documented on the mapserver utilities page of the website. It is used to
> tiling shapefiles. The easiest way to use it is to putt all the data you
> want to tile in a directory tree located in your SHAPEPATH directory.
> Then on Linux do something like:
> find data_dir -name "*.shp" > data_dir.in
> tile4ms data_dir.in data-tile
> shptree data-tile
> cat data_dir.in | xargs -n 1 shptree
> Then in your mapfile do something like:
> LAYER
> NAME "my tile data"
> TYPE whatever
> TILEINDEX data-tile
> CLASS
> END
> END
> One of the caveats of this is that all the shapefiles in the index MUST
> have the SAME attributes and order of attributes and they must be all
> the same type.
> 2) For tiling images you should use gdaltindex which is distributed as
> part of the gdal libraries and tools. The concept is similar to the
> above and I documented it on the wiki at
> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?RasterHOWTO
> in the Bathymetry and Topography HowTo link and others have added a lot
> more info there.
