Tiger Line Data
Hermawan Sutantio
hermawan_s at HOTMAIL.COM
Mon Feb 28 23:46:57 EST 2005
Thanks,for your help.
It helps in an instant.
I'm trying to display feature labels of the roads.
LAYER
NAME "Michigan Labels"
TYPE ANNOTATION
STATUS DEFAULT
TILEINDEX "C:\ms4w\apps\gmap\htdocs\michigan\mich-tile"
LABELMAXSCALE 100000
CLASS
Name "Michigan Labels"
LABEL
TYPE TRUETYPE
FONT "arial"
SIZE 10
ANGLE AUTO
POSITION uc
END
END # Class
END
Does this layer...end code make any sense?
Thanks again.
Herman
Hermawan,
See comments below
Hermawan Sutantio wrote:
>Hi all.
>I might need some more help.
>Based on the recommendation that Stephen gave, I tried to compile 2
>counties
>in michigan using the commands recommended. Below is the michigan.map file
>that i generated. Please help me review them whether anything is wrong.
>Thanks.
You need to start your mapfile with:
MAP
>FONTSET "C:\MS4W\apps\maplab-2.2\tutorial\etc\fonts.list"
># Start of map file
>NAME Michigan
>STATUS ON
>SIZE 500 500
>UNITS DD
>EXTENT -84.133748 42.072069 -83.539394 42.4345936
>SHAPEPATH "C:\cygwin\hcslmap\data\tiger"
>IMAGECOLOR 255 255 255
># Start of web interface definition
>WEB
># On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the root
># of the drive where the .MAP file resides.
> IMAGEPATH "C/ms4w/tmp/ms_tmp/"
Are you missing a ":" as in "C:"
> IMAGEURL "/ms_tmp/"
># LOG "/tmp/gmap.log"
> TEMPLATE demo.html
> METADATA
> "TITLE" "Michigan Test Demo"
> END
>END
># Start of legend
>LEGEND
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> STATUS OFF
>END
># Start of scalebar
>SCALEBAR
> LABEL
> COLOR 0 0 0
> SIZE SMALL
> END
> SIZE 150 4
> COLOR 255 255 255
> BACKGROUNDCOLOR 0 0 0
> OUTLINECOLOR 0 0 0
> UNITS miles
> INTERVALS 3
> STATUS ON
>END
># Querymap settings
># Style is one of NORMAL, HILITE, or SELECTED
>QUERYMAP
> STYLE HILITE
> COLOR 255 0 0
>END
># Start of layer definitions
>LAYER
> NAME Street_Map
> TYPE LINE
> STATUS ON
STATUS ON says that you can display the layer, but not that it WILL be
desplayed. Until you understand this, I would use
STATUS DEFAULT
> TILEINDEX "C:\cygwin\hcslmap\data\tiger\mich-tile.shp"
> CLASS
> NAME "Street_Map"
You probably need to specify the color and style of the line. Try
COLOR 0 0 0 # black
SIZE 1 # one pixel width
> END
>END # Layer
>END #map
>Herman Teo wrote:
>>Hi Stephen,
>>Thanks for the tip. I'm now scouring through the previous list
>>messages for 'tile' commands. There is not much of that going on. Is
>>there a sample code where I might be able to learn how I should
>>proceed with shape tiling and a sniff of a LAYER...END code in the
>>map file. Also, is any of these tiger line on sale somewhere so that
>>I might not have to download 300k files as you said. Thanks a lot.
>Herman,
>There are two different tiling commands:
>1) tile4ms which is distributed as part of the mapserver source and is
>documented on the mapserver utilities page of the website. It is used to
>tiling shapefiles. The easiest way to use it is to putt all the data you
>want to tile in a directory tree located in your SHAPEPATH directory.
>Then on Linux do something like:
>find data_dir -name "*.shp" > data_dir.in
>tile4ms data_dir.in data-tile
>shptree data-tile
>cat data_dir.in | xargs -n 1 shptree
>Then in your mapfile do something like:
>LAYER
> NAME "my tile data"
> TYPE whatever
> TILEINDEX data-tile
> CLASS
> END
>END
>One of the caveats of this is that all the shapefiles in the index MUST
>have the SAME attributes and order of attributes and they must be all
>the same type.
>2) For tiling images you should use gdaltindex which is distributed as
>part of the gdal libraries and tools. The concept is similar to the
>above and I documented it on the wiki at
>http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?RasterHOWTO
>in the Bathymetry and Topography HowTo link and others have added a lot
>more info there.
