GetFeatureInfo problem
François Prunayre
fx.prunayre at OIEAU.FR
Fri Jul 1 09:39:50 EDT 2005
Hi José, Try to add gml_include_items in your metadata for the layer ...
DUMP TRUE
METADATA
"ows_title" "LAYER TITLE"
"ows_srs" "EPSG:XXX"
"ows_group_title" "LAYER GROUP"
"ows_extent" "0 1600000 1200000 2800000"
"gml_include_items" "all"
END
HTH
Francois
-----Message d'origine-----
De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la
part de José Vicente Higón Valero
Envoyé : vendredi 1 juillet 2005 14:00
À : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : [UMN_MAPSERVER-USERS] GetFeatureInfo problem
I have installed mapserver 4.6.0 on suse 9.0 with postgis 1.0.1. When I
request a GetFeatureInfo, the response hasn't information about the
atributes. I get this:
<?xml version="1.0" encoding="ISO-8859-1"?>
<msGMLOutput
xmlns:gml="http://www.opengis.net/gml"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<embalses_layer>
<embalses_feature>
<gml:boundedBy>
<gml:Box srsName="EPSG:23030">
<gml:coordinates>620344.450000,4377612.070000
632854.690000,4394243.500000</gml:coordinates>
</gml:Box>
</gml:boundedBy>
</embalses_feature>
</embalses_layer>
</msGMLOutput>
But I must get:
<msGMLOutput
<embalses_layer>
<embalses_feature>
<gid>28</gid>
<entity>Complex Shape</entity>
<layer>55</layer>
<level>55</level>
<elevation>0</elevation>
<color>1</color>
<mslink_dmr>0</mslink_dmr>
<codigo>Embalse de Contreras</codigo>
<tipo>Embalses</tipo>
<gml:boundedBy>
Any clue?
I have compiled mapserver:
./configure --prefix=/usr/local --with-wms --with-wfs --with-wcs
--with-wmsclient --with-wfsclient --with-gd --with-proj --with-geos
--with-freetype --with-gdal=/usr/local/bin/gdal-config
--with-ogr=/usr/local/bin/gdal-config
--with-postgis=/usr/local/pgsql/bin/pg_config
--with-curl-config=/usr/local/bin/curl-config --with-jpeg --with-tiff
--with-httpd=/usr/local/apache2/bin/httpd
--with-mygis=/usr/local/mysql/bin/mysql_config
And the configuration of the map file:
LAYER
NAME "embalses"
GROUP "CV300k"
STATUS ON
DUMP TRUE
TEMPLATE "."
DATA "the_geom from embalses"
TYPE POLYGON
TRANSPARENCY 10
CONNECTIONTYPE POSTGIS
CONNECTION "user=gis dbname=cv300k host=127.0.0.1 port=5432"
METADATA
"wms_name" "embalses"
"wms_title" "Embalses"
"wms_abstract" "embalses"
"wms_keywordlist" "embalses,valencia"
"wms_srs" "EPSG:23030 EPSG:4326"
"wms_group_title" "CV300k"
"wms_extent" "600000 4180000 810000 4530000"
END
CLASS
# NAME "embalses"
COLOR 0 204 255
OUTLINECOLOR 0 0 255
END
END
Thanks in advance.
José Vicente Higón
gvSIG development Team
Conselleria de Infraestructuras y Transporte
Generalitat Valenciana
Valencia - Spain
tlf. 963862397
http://www.gvsig.gva.es
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et
rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels,
confidentiels et prives. Toute publication, utilisation ou diffusion, meme
partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal,
confidential and secret. Any total or partial publication, use or
distribution must be authorized.
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels, confidentiels et prives. Toute publication, utilisation ou diffusion, meme partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal, confidential and secret. Any total or partial publication, use or distribution must be authorized.
