Log error question
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Wed Jul 20 08:21:12 EDT 2005
This sounds like it might be a data problem with the layer you are
having problems with. If you have a bad file or a bad object in the file
it would work most of the time but only crash when you are at the
correct zoom scale and at the correct spatial extents to cause the
object to be rendered.
There used to be a utility called chkshp or checkshp or something like
that that you can run on shape files to check them. You might want to
consider doing that to make sure it is not a data problem.
-Steve W.
Stéphane RIFF wrote:
> I really don't understand because when i turn DEBUG ON my never crash
> I know it's really strange but it's what i see....
> I use php 4.3.9 and i saw on php.net that php 4.4.0 release had resolve
> some
> bug on references : Do you think that i had to update my php version ???
>> Hello,
>> I have some problem on a phpmapscript application. Some time it seems
>> that
>> $map->draw() crash for unknown reason. It's not logical (I think), it
>> happened
>> randomly but only when a specific layer is on.
>> What i want to know is to debug phpmapscript, so i made an
>> error_handler for my php script
>> but i didn't log the phpmapscript errors. So i tried map DEBUG but the
>> informations
>> are very orientated for time performance. Is it possible to log only
>> crash ???
>> Hope this clear...
>> Thanks
>> Steff
