Log error question
    Stéphane RIFF
    stephane.riff at CERENE.FR
    Wed Jul 20 05:55:44 PDT 2005
Thanks for your answer.
All my data are stored in POSTGIS so i can't use your utility.
About the scale i tried at the same scale with DEBUG ON and OFF
When it's ON  -> no crash
When it's OFF -> crash
Maybe my layer def is bad, i have post about my layer definition but had
no answer
I resend it here.
This layer represent some car track on one day, i use gps date to
delimitate each path.
It a bit long but hope someone could tell me if it's really bad to do this :
The data table structure is :
    |           gps_date            | speed | altitude | heading |
engine_onoff |
geom                                    |
      2005-06-27 04:58:20  |   100  |   350    |  159      |
1            |   SRID=4326;POINT(2.315729 48.777176)
      2005-06-27 04:59:19  |    90   |    345   |   120     |
1            |   SRID=4326;POINT(2.314061 48.771334)
-       |       0            |                          -
-       |       0            |                          -
-       |       0            |                          -
-       |       1            |                          -
and so on .....
The field engine_onoff represent each track when it's 1 the engine is
power on
when it's 0 the engine is power off.
My goal is that all path (engine_onoff == 1) are represents in a
different color. (  I use seven colors and rotate )
At this time i use a sql query to determinate all tracks starts and
ends, then create a dynamic layer via phpmapscript.
Here is the layer definition
LAYER
   CLASSITEM "gps_date"
   CONNECTION "host=localhost dbname=database1 port=5432 user=usr1
password=pwd1"
   CONNECTIONTYPE POSTGIS
   DATA "geom from history"
     FILTER ( (natural_id=1002514153) AND (TIMESTAMP '2005-06-27
00:00:01',TIMESTAMP '2005-06-27 23:59:59') OVERLAPS (gps_date,INTERVAL
'0 days'))
   GROUP "G.P.S"
   LABELANGLEITEM "heading"
   LABELCACHE OFF
     METADATA
     END
   NAME "GPS_REM"
   PROJECTION
     "init=epsg:4326"
   END
   SIZEUNITS PIXELS
   STATUS ON
   TOLERANCE 6
   TOLERANCEUNITS PIXELS
   TRANSPARENCY 1000
   TYPE ANNOTATION
   UNITS METERS
   CLASS
     NAME "0"
     EXPRESSION ( ('[gps_date]' >= '2005-07-11 06:57:06' AND
'[gps_date]' < '2005-07-11 07:02:36')
                               OR ('[gps_date]' >= '2005-07-11 12:16:09'
AND '[gps_date]' < '2005-07-11 12:18:49')
                               OR ('[gps_date]' >= '2005-07-11 17:29:04'
AND '[gps_date]' < '2005-07-11 17:37:54')
                               OR ('[gps_date]' >= '2005-07-11 19:18:58'
AND '[gps_date]' < '2005-07-11 19:19:13')
                               OR ('[gps_date]' >= '2005-07-11 20:24:25'
AND '[gps_date]' < '2005-07-11 20:38:05') )
     LABEL
       ANGLE -21.000000
       ANTIALIAS TRUE
       FONT Symbols
       MAXSIZE 256
       MINSIZE 4
       SIZE 14
       TYPE TRUETYPE
       BUFFER 0
       COLOR 0 128 128
       FORCE TRUE
       MINDISTANCE -1
       MINFEATURESIZE -1
       OFFSET 0 0
       PARTIALS TRUE
       POSITION CC
           END
     METADATA
     END
     STYLE
         COLOR 0 0 255
       MAXSIZE 500
       MINSIZE 1
       SIZE 14
       SYMBOL "point"
     END
     TEMPLATE "dummy"
     TEXT "b"
   END
   CLASS
     NAME "1"
     EXPRESSION ( ('[gps_date]' >= '2005-07-11 07:10:19' AND
'[gps_date]' < '2005-07-11 07:48:45')
                               OR ('[gps_date]' >= '2005-07-11 12:18:49'
AND '[gps_date]' < '2005-07-11 12:34:15')
                               OR ('[gps_date]' >= '2005-07-11 17:37:54'
AND '[gps_date]' < '2005-07-11 18:00:53')
                               OR ('[gps_date]' >= '2005-07-11 19:29:20'
AND '[gps_date]' < '2005-07-11 19:30:05')
                               OR ('[gps_date]' >= '2005-07-11 20:38:05'
AND '[gps_date]' < '2005-07-11 20:44:50') )
     LABEL
       ANGLE -21.000000
       ANTIALIAS TRUE
       FONT Symbols
       MAXSIZE 256
       MINSIZE 4
       SIZE 14
       TYPE TRUETYPE
       BUFFER 0
       COLOR 0 0 128
       FORCE TRUE
       MINDISTANCE -1
       MINFEATURESIZE -1
       OFFSET 0 0
       PARTIALS TRUE
       POSITION CC
     END
     METADATA
     END
     STYLE
         COLOR 0 0 255
       MAXSIZE 500
       MINSIZE 1
       SIZE 14
       SYMBOL "point"
     END
     TEMPLATE "dummy"
     TEXT "b"
   END
       CLASS
     NAME "2"
     EXPRESSION ( ('[gps_date]' >= '2005-07-11 07:56:22' AND
'[gps_date]' < '2005-07-11 08:00:22')
                               OR ('[gps_date]' >= '2005-07-11 12:37:30'
AND '[gps_date]' < '2005-07-11 12:44:30')
                               OR ('[gps_date]' >= '2005-07-11 18:00:53'
AND '[gps_date]' < '2005-07-11 18:33:29')
                               OR ('[gps_date]' >= '2005-07-11 19:37:37'
AND '[gps_date]' < '2005-07-11 19:39:52')
                               OR ('[gps_date]' >= '2005-07-11 20:44:50'
AND '[gps_date]' < '2005-07-11 20:46:35') )
     LABEL
       ANGLE -168.000000
       ANTIALIAS TRUE
       FONT Symbols
       MAXSIZE 256
       MINSIZE 4
       SIZE 14
       TYPE TRUETYPE
       BUFFER 0
       COLOR 128 0 128
       FORCE TRUE
       MINDISTANCE -1
       MINFEATURESIZE -1
       OFFSET 0 0
       PARTIALS TRUE
       POSITION CC
     END
     METADATA
     END
     STYLE
         COLOR 0 0 255
       MAXSIZE 500
       MINSIZE 1
       SIZE 14
       SYMBOL "point"
     END
     TEMPLATE "dummy"
     TEXT "b"
   END
   CLASS
     NAME "3"
     EXPRESSION ( ('[gps_date]' >= '2005-07-11 08:02:07' AND
'[gps_date]' < '2005-07-11 08:19:54')
                               OR ('[gps_date]' >= '2005-07-11 15:21:47'
AND '[gps_date]' < '2005-07-11 15:38:00')
                               OR ('[gps_date]' >= '2005-07-11 18:33:29'
AND '[gps_date]' < '2005-07-11 18:42:53')
                               OR ('[gps_date]' >= '2005-07-11 19:52:07'
AND '[gps_date]' < '2005-07-11 20:05:55')
                               OR ('[gps_date]' >= '2005-07-11 20:47:35'
AND '[gps_date]' < '2005-07-11 20:47:50') )
     LABEL
       ANGLE -261.000000
       ANTIALIAS TRUE
       FONT Symbols
       MAXSIZE 256
       MINSIZE 4
       SIZE 14
       TYPE TRUETYPE
               BUFFER 0
       COLOR 128 128 128
       FORCE TRUE
       MINDISTANCE -1
       MINFEATURESIZE -1
       OFFSET 0 0
       PARTIALS TRUE
       POSITION CC
     END
     METADATA
     END
     STYLE
         COLOR 0 0 255
       MAXSIZE 500
       MINSIZE 1
       SIZE 14
       SYMBOL "point"
     END
     TEMPLATE "dummy"
     TEXT "b"
   END
   CLASS
     NAME "4"
     EXPRESSION ( ('[gps_date]' >= '2005-07-11 08:20:09' AND
'[gps_date]' < '2005-07-11 08:21:24')
                               OR ('[gps_date]' >= '2005-07-11 15:41:45'
AND '[gps_date]' < '2005-07-11 16:53:00')
                               OR ('[gps_date]' >= '2005-07-11 18:42:53'
AND '[gps_date]' < '2005-07-11 18:46:38')
                               OR ('[gps_date]' >= '2005-07-11 20:05:55'
AND '[gps_date]' < '2005-07-11 20:10:40')
                               OR ('[gps_date]' >= '2005-07-11 21:24:58'
AND '[gps_date]' < '2005-07-11 21:25:28') )
     LABEL
       ANGLE -286.000000
       ANTIALIAS TRUE
       FONT Symbols
       MAXSIZE 256
       MINSIZE 4
       SIZE 14
       TYPE TRUETYPE
       BUFFER 0
       COLOR 0 0 0
       FORCE TRUE
       MINDISTANCE -1
       MINFEATURESIZE -1
       OFFSET 0 0
       PARTIALS TRUE
       POSITION CC
     END
     METADATA
     END
     STYLE
         COLOR 0 0 255
       MAXSIZE 500
               MINSIZE 1
       SIZE 14
       SYMBOL "point"
     END
     TEMPLATE "dummy"
     TEXT "b"
   END
   CLASS
     NAME "5"
     EXPRESSION ( ('[gps_date]' >= '2005-07-11 08:46:27' AND
'[gps_date]' < '2005-07-11 09:15:20')
                               OR ('[gps_date]' >= '2005-07-11 16:53:00'
AND '[gps_date]' < '2005-07-11 17:20:19')
                               OR ('[gps_date]' >= '2005-07-11 18:55:38'
AND '[gps_date]' < '2005-07-11 18:59:08')
                               OR ('[gps_date]' >= '2005-07-11 20:10:40'
AND '[gps_date]' < '2005-07-11 20:20:10') )
     LABEL
       ANGLE -11.000000
       ANTIALIAS TRUE
       FONT Symbols
       MAXSIZE 256
       MINSIZE 4
       SIZE 14
       TYPE TRUETYPE
       BUFFER 0
       COLOR 128 128 0
       FORCE TRUE
       MINDISTANCE -1
       MINFEATURESIZE -1
       OFFSET 0 0
       PARTIALS TRUE
       POSITION CC
     END
     METADATA
     END
     STYLE
         COLOR 0 0 255
       MAXSIZE 500
       MINSIZE 1
       SIZE 14
       SYMBOL "point"
     END
     TEMPLATE "dummy"
     TEXT "b"
   END
   CLASS
     NAME "6"
     EXPRESSION ( ('[gps_date]' >= '2005-07-11 11:21:04' AND
'[gps_date]' < '2005-07-11 11:50:10')
                               OR ('[gps_date]' >= '2005-07-11 17:20:19'
AND '[gps_date]' < '2005-07-11 17:29:04')
                               OR ('[gps_date]' >= '2005-07-11 19:12:43'
AND '[gps_date]' < '2005-07-11 19:16:58')
                               OR ('[gps_date]' >= '2005-07-11 20:20:10'
AND '[gps_date]' < '2005-07-11 20:21:25') )
     LABEL
       ANGLE -6.000000
       ANTIALIAS TRUE
               FONT Symbols
       MAXSIZE 256
       MINSIZE 4
       SIZE 14
       TYPE TRUETYPE
       BUFFER 0
       COLOR 255 0 255
       FORCE TRUE
       MINDISTANCE -1
       MINFEATURESIZE -1
       OFFSET 0 0
       PARTIALS TRUE
       POSITION CC
     END
     METADATA
     END
     STYLE
         COLOR 0 0 255
       MAXSIZE 500
       MINSIZE 1
       SIZE 14
       SYMBOL "point"
     END
     TEMPLATE "dummy"
     TEXT "b"
   END
   CLASS
     NAME "stop"
     EXPRESSION ( ('[gps_date]' eq '2005-07-10 23:04:48')  OR
('[gps_date]' eq '2005-07-11 07:02:36')
                               OR ('[gps_date]' eq '2005-07-11
07:48:45')  OR ('[gps_date]' eq '2005-07-11 07:53:52')
08:00:22')  OR ('[gps_date]' eq '2005-07-11 08:19:54')
08:21:24')  OR ('[gps_date]' eq '2005-07-11 08:22:24')
09:15:20')  OR ('[gps_date]' eq '2005-07-11 11:50:10')
12:34:15')  OR ('[gps_date]' eq '2005-07-11 12:44:30')
13:39:04')  OR ('[gps_date]' eq '2005-07-11 15:38:00')
18:46:38')  OR ('[gps_date]' eq '2005-07-11 18:59:08')
19:16:58')  OR ('[gps_date]' eq '2005-07-11 19:19:13')
19:30:05')  OR ('[gps_date]' eq '2005-07-11 19:34:37')
19:34:52')  OR ('[gps_date]' eq '2005-07-11 19:39:52')
19:41:52')  OR ('[gps_date]' eq '2005-07-11 19:45:22')
19:45:37')  OR ('[gps_date]' eq '2005-07-11 19:48:37')
19:48:52')  OR ('[gps_date]' eq '2005-07-11 19:50:07')
20:21:25')  OR ('[gps_date]' eq '2005-07-11 20:23:55')
20:46:35')  OR ('[gps_date]' eq '2005-07-11 20:47:50')
21:25:28')  OR ('[gps_date]' eq '2005-07-11 22:38:02') )
     LABEL
       ANGLE -244.000000
       ANTIALIAS TRUE
       FONT Symbols
       MAXSIZE 256
       MINSIZE 4
       SIZE 14
       TYPE TRUETYPE
       BUFFER 0
       COLOR 255 0 0
       FORCE TRUE
               MINDISTANCE -1
       MINFEATURESIZE -1
       OFFSET 0 0
       PARTIALS TRUE
       POSITION CC
     END
     METADATA
     END
     TEMPLATE "dummy"
     TEXT "f"
   END
 END
Stephen Woodbridge wrote:
> This sounds like it might be a data problem with the layer you are
> having problems with. If you have a bad file or a bad object in the
> file it would work most of the time but only crash when you are at the
> correct zoom scale and at the correct spatial extents to cause the
> object to be rendered.
> There used to be a utility called chkshp or checkshp or something like
> that that you can run on shape files to check them. You might want to
> consider doing that to make sure it is not a data problem.
> -Steve W.
> Stéphane RIFF wrote:
>> I really don't understand because when i turn DEBUG ON my never crash
>> I know it's really strange but it's what i see....
>> I use php 4.3.9 and i saw on php.net that php 4.4.0 release had
>> resolve some
>> bug on references : Do you think that i had to update my php version ???
>>> Hello,
>>> I have some problem on a phpmapscript application. Some time it
>>> seems that
>>> $map->draw() crash for unknown reason. It's not logical (I think),
>>> it happened
>>> randomly but only when a specific layer is on.
>>> What i want to know is to debug phpmapscript, so i made an
>>> error_handler for my php script
>>> but i didn't log the phpmapscript errors. So i tried map DEBUG but
>>> the informations
>>> are very orientated for time performance. Is it possible to log only
>>> crash ???
>>> Hope this clear...
>>> Thanks
>>> Steff
More information about the MapServer-users
