coordinates with jBox
Jachym Cepicky jachym.cepicky at CENTRUM.CZ
Tue Jul 26 02:59:20 EDT 2005
hallo,
On Mon, Jul 25, 2005 at 09:17:54PM -0600, Richard Greenwood wrote:
> Hello Jáchym,
> When lineon == true, measure_handler() will be called when user clicks
> mouse. measure_handler() does not return mouse coordinates, but if you
> set applet parameter verbose=true, then the javascript handler
> mouseenter_handler() will be called each time the mouse moves more than
> 'jitter' pixels. So save these coordinates in js variables, then fetch
> them in measure_handler().
> Regards,
Good hint. But the measure_handler stores *all* the values, depending
on jitter and *not* on mouse click. All the coordinates, over which I
move the mouse will be saved.
I need only those of them, which are "under" the mouse click.
In measure_handler():
                if (document.mapserv.tool.value == "analyze") {
                      document.mapserv.points.value = document.forms[0].points.value + document.forms[0].curr_point.value;
                      //console(document.mapserv.points.value );
How to do this?
Thanks
Jachym
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/
