SWIGMapscript: glibc detected malloc memory corruption
Geo-IT GmbH info at GEO-IT.COM
Mon Jun 27 05:22:05 EDT 2005
Hi Umberto,
Sorry, forgot to reply to the list, this time I remember ;-)
This was my configure String for mapserver 4.6.0:
./configure --with-tiff=/usr/local/mslibs --with-jpeg=/usr/local/mslibs
--with-png --with-proj=/usr/local/mslibs --with-wmsclient
--with-postgis=/usr/local/pgsql/bin/pg_config --with-php=../../php-4.3.8
--with-python --with-freetype --with-gd=/usr/local/mslibs --with-tcl
--with-threads=-lpthread --with-wfs --with-wfsclient --with-wcs
--with-gdal=/usr/local/mslibs/bin/gdal-config
--with-ogr=/usr/local/mslibs/bin/gdal-config --enable-debug
--with-httpd=/usr/sbin/httpd2-prefork
--with-oraclespatial=/opt/oracle/product/9.2.0
--with-geos=/usr/local/mslibs/bin/geos-config
Thanks for the tip that library load is done by mapscript.jar.
Mit freundlichen Gruessen/Kind regards
Andreas Paukner-Ruzicka
(Geschaeftsfuehrer/Managing director)
Geo-IT GmbH   -   Geoinformatik, IT-Services
Guggenberg 3, D-82380 Peissenberg
Tel: 08803-498372, Fax: 08803-498373
eMail: info at geo-it.com  -  Homepage: http://www.geo-it.com
On Mon, June 27, 2005 10:45, Umberto Nicoletti said:
> Next time please reply to the list too (the mailin list admin could
> setup the list software so that it rewrites the reply-to field and
> make the list work like all other lists I've subscribed to).
> Comments inline.
> On 6/27/05, Geo-IT GmbH <info at geo-it.com> wrote:
>> Hi Umberto,
>> Thanks for your reply.
>> I am using SuSE 9.3 i686 (32 Bit).
>> After some additional tests I found that among others it has something to do
>> with the data and the projection of the data. Therefore I meanwhile managed
>> to
>> get the testprogram running (the one attached in my mail) but it is still
>> falling over when trying to do the same thing from within a servlet.
> What configure options did you use?
> In particular have you enabled the thread locks with use-threads?
> Notice: since 4.4.something it is not necessary to load the library
> anymore as that is done in the mapscript.jar.
> Regards,
> Umberto
>> That is
>> not my first Java Servlet program using mapscript functions, so I could
>> claim
>> to be no novice to java mapscript. But up to and including mapserver version
>> 4.0 I used the processTemplate, and processQueryTemplate methods to generate
>> result HTML pages but this is no longer working since 4.2. (I reported this
>> bug, but it seems to be more complex than expected to solve this). Therefore
>> it's the first time to fetch the results of a query one after one and
>> filling
>> a template manually.
>> I'll try the MALLOC_CHECK_ variable and read through the malloc man page.
>> On Mon, June 27, 2005 9:47, Umberto Nicoletti said:
>> > What distro are you using (this appears to be a detail too often
>> forgotten) ?
>> > See if you have a MALLOC_CHECK_ env variable set and then read
>> > malloc's man page.
>> > Regards,
>> > Umberto
>> > On 6/26/05, Geo-IT GmbH <info at geo-it.com> wrote:
>> >> Dear experts,
>> >> When trying to fetch a shapeObj after a queryByPoint using the shapeindex
>> >> and
>> >> tileindex from the resultCache in a Java mapscript program I get the
>> >> following
>> >> error terminating the whole VM:
>> >> *** glibc detected *** malloc(): memory corruption: 0x08314ed0 ***
>> >> ./runshapetest40.sh: line 13: 26946 Aborted java ShapeObjTest40 $mapfile
>> >> $layername
>> >> The program was:
>> >> // Standard imports
>> >> import java.io.*;
>> >> import java.util.*;
>> >> import java.text.*;
>> >> import edu.umn.gis.mapscript.*;
>> >> public class ShapeObjTest {
>> >>         String mapFile = null;
>> >>         String layerName = null;
>> >> static {
>> >>         try {
>> >>                 System.loadLibrary("mapscript");
>> >>                 System.out.println("Mapscript lib loaded");
>> >>         } catch (UnsatisfiedLinkError e) {
>> >>                 e.printStackTrace();
>> >>                 System.exit(1);
>> >>         public ShapeObjTest() {
>> >>         protected static void log(String msg) {
>> >>                 System.out.println(msg);
>> >>         protected static void usage() {
>> >>                 System.out.println("USAGE: ShapeObjTest <mapfile>
>> >> <layername>");
>> >>         public static void main (String args[] ) {
>> >>                 if (args == null || args.length < 2) {
>> >>                         usage();
>> >>                         System.exit(1);
>> >>                 String mapFile = args[0];
>> >>                 String layerName = args[1];
>> >>         try {
>> >>                 log("Creating map");
>> >>                 mapObj map = new mapObj(mapFile);
>> >>                 layerObj l = map.getLayerByName(layerName);
>> >>                 l.open();
>> >>                 log("Fetching shapeObj shapeindex 1 tileindex -1");
>> >>                 shape = l.getFeature(1,-1);
>> >>                 l.close();
>> >>                 log("Fetch successful");
>> >>         } catch (Exception ie) {
>> >>                 ie.printStackTrace();
>> >>                 System.exit(1);
>> >> The log shows:
>> >> Creating map
>> >> Then the error appears on the console.
>> >> I use mapserver 4.6.0.
>> >> This is the mapfile: (It's the one from Itasca demo, but only with layer
>> >> airports)
>> >> MAP
>> >>   # Start of map file
>> >>   NAME "DEMO"
>> >>   STATUS ON
>> >>   EXTENT 388107.634400379 5203120.88405952 500896.339019834
>> 5310243.30613897
>> >>   SIZE 600 600
>> >>   SHAPEPATH "data"
>> >>   IMAGECOLOR 255 255 255
>> >>   UNITS METERS
>> >>   # you may need to change this to match your MapServer build
>> >>   #IMAGETYPE PNG
>> >>   # Projection definition, consult the PROJ.4 documentation for parameter
>> >> discussion
>> >>   PROJECTION
>> >>     "proj=utm"
>> >>     "ellps=GRS80"
>> >>     "zone=15"
>> >>     "north"
>> >>     "no_defs"
>> >> #  OR:
>> >>   #  "init=epsg:26915"
>> >>   END
>> >>   # Start of web interface definition (including WMS enabling metadata)
>> >>   WEB
>> >>     MINSCALE 1000
>> >>     MAXSCALE 1550000
>> >>     IMAGEPATH "/tmp"
>> >>     IMAGEURL "/tmp"
>> >>     HEADER "demo_header.html"
>> >>     FOOTER "demo_footer.html"
>> >>     TEMPLATE "demo.html"
>> >>     METADATA
>> >>       "WMS_TITLE"    "UMN MapServer Itasca Demo"
>> >>       "WMS_ABSTRACT"    "This is the UMN MapServer demonstration
>> application
>> >> for Itasca County located in north central Minnesota."
>> >>       "WMS_ACCESSCONSTRAINTS"    "none"
>> >>       "WMS_ONLINERESOURCE"
>> >> "http://localhost.localdomain/mapserver_demos/itasca/demo_init.html"
>> >>       "WMS_SRS"    "EPSG:26915"
>> >>     END
>> >>   END
>> >>   # Start of reference map
>> >>   REFERENCE
>> >>     STATUS ON
>> >>     IMAGE "graphics/reference.gif"
>> >>     SIZE 120 120
>> >>     EXTENT 393234.393701263 5205405.16440722 495769.579718949
>> >> 5307959.02579127
>> >>     COLOR -1 -1 -1
>> >>     OUTLINECOLOR 255 0 0
>> >>   END
>> >>   QUERYMAP
>> >>     STATUS ON
>> >>     SIZE 200 200
>> >>     COLOR 255 0 0
>> >>     STYLE HILITE
>> >>   END
>> >>   # Start of legend
>> >>   LEGEND
>> >>     STATUS ON
>> >>     KEYSIZE 18 12
>> >>     LABEL
>> >>       TYPE BITMAP
>> >>       SIZE MEDIUM
>> >>       COLOR 0 0 89
>> >>     END
>> >>   END
>> >>   # Start of scalebar
>> >>   SCALEBAR
>> >>     STATUS ON
>> >>     COLOR 0 102 102
>> >>     OUTLINECOLOR 102 255 0
>> >>     BACKGROUNDCOLOR 255 51 102
>> >>     TRANSPARENT OFF
>> >>     UNITS MILES
>> >>     INTERVALS 1
>> >>     SIZE 80 2
>> >>     STYLE 1
>> >>     INTERLACE ON
>> >>     LABEL
>> >>       TYPE BITMAP
>> >>       SIZE MEDIUM
>> >>       COLOR 0 0 0
>> >>     END
>> >>   END
>> >>   # Start of symbol definitions (we're only using a few)
>> >>   SYMBOL
>> >>     NAME "circle"
>> >>     TYPE ELLIPSE
>> >>     FILLED TRUE
>> >>     POINTS
>> >>        1 1
>> >>     END
>> >>   END
>> >>   # Start of layer definitions
>> >>   LAYER
>> >>     NAME "airports"
>> >>     STATUS OFF
>> >>     DATA "airports"
>> >>     TYPE POINT
>> >>     TOLERANCE 5
>> >>     HEADER "airports_header.html"
>> >>     FOOTER "airports_footer.html"
>> >>     TEMPLATE "ttt.html"
>> >>     METADATA
>> >>       "WMS_TITLE"    "Airports"
>> >>       "WMS_ABSTRACT"    "Airport runways for Itasca County."
>> >>     END
>> >>     CLASS
>> >>       NAME "Airports"
>> >>       SYMBOL "circle"
>> >>       COLOR 128 255 164
>> >>       SIZE 7
>> >>       TEMPLATE "airports.html"
>> >>     END
>> >>   END
>> >> Any help would be greatly appreciated.
