SWIGMapscript: glibc detected malloc memory corruption
Umberto Nicoletti umberto.nicoletti at GMAIL.COM
Mon Jun 27 05:32:32 EDT 2005
On 6/27/05, Geo-IT GmbH <info at geo-it.com> wrote:
> Hi Umberto,
> Sorry, forgot to reply to the list, this time I remember ;-)
> This was my configure String for mapserver 4.6.0:
> ./configure --with-tiff=/usr/local/mslibs --with-jpeg=/usr/local/mslibs
> --with-png --with-proj=/usr/local/mslibs --with-wmsclient
> --with-postgis=/usr/local/pgsql/bin/pg_config --with-php=../../php-4.3.8
> --with-python --with-freetype --with-gd=/usr/local/mslibs --with-tcl
> --with-threads=-lpthread --with-wfs --with-wfsclient --with-wcs
> --with-gdal=/usr/local/mslibs/bin/gdal-config
> --with-ogr=/usr/local/mslibs/bin/gdal-config --enable-debug
> --with-httpd=/usr/sbin/httpd2-prefork
> --with-oraclespatial=/opt/oracle/product/9.2.0
> --with-geos=/usr/local/mslibs/bin/geos-config
Gee, what a setup!
I have learned from the ML (somebody could confirm) that mixing tiff
and gdal is not good: so if you use gdal then say --without-tiff.
I see that you have some mapserver libraries installed in
/usr/local/mslibs: how do you make sure that mapserver picks those up
instead of the system provided (gd,png,tiff for example)?
Then do you really need php/python/tcl/wfs/postgis/oracle/wcs? If not
disable the ones that you do not use, this will reduce the likeliness
of mapserver/mapscript errors (I'd recommend to take a conservative
approach when using Java mapscript).
HTH,
Umberto
> Thanks for the tip that library load is done by mapscript.jar.
> Mit freundlichen Gruessen/Kind regards
> Andreas Paukner-Ruzicka
> (Geschaeftsfuehrer/Managing director)
> Geo-IT GmbH   -   Geoinformatik, IT-Services
> Guggenberg 3, D-82380 Peissenberg
> Tel: 08803-498372, Fax: 08803-498373
> eMail: info at geo-it.com  -  Homepage: http://www.geo-it.com
> On Mon, June 27, 2005 10:45, Umberto Nicoletti said:
> > Next time please reply to the list too (the mailin list admin could
> > setup the list software so that it rewrites the reply-to field and
> > make the list work like all other lists I've subscribed to).
> > Comments inline.
> >> Hi Umberto,
> >> Thanks for your reply.
> >> I am using SuSE 9.3 i686 (32 Bit).
> >> After some additional tests I found that among others it has something to do
> >> with the data and the projection of the data. Therefore I meanwhile managed
> >> to
> >> get the testprogram running (the one attached in my mail) but it is still
> >> falling over when trying to do the same thing from within a servlet.
> > What configure options did you use?
> > In particular have you enabled the thread locks with use-threads?
> > Notice: since 4.4.something it is not necessary to load the library
> > anymore as that is done in the mapscript.jar.
> > Regards,
> > Umberto
> >> That is
> >> not my first Java Servlet program using mapscript functions, so I could
> >> claim
> >> to be no novice to java mapscript. But up to and including mapserver version
> >> 4.0 I used the processTemplate, and processQueryTemplate methods to generate
> >> result HTML pages but this is no longer working since 4.2. (I reported this
> >> bug, but it seems to be more complex than expected to solve this). Therefore
> >> it's the first time to fetch the results of a query one after one and
> >> filling
> >> a template manually.
> >> I'll try the MALLOC_CHECK_ variable and read through the malloc man page.
> >> On Mon, June 27, 2005 9:47, Umberto Nicoletti said:
> >> > What distro are you using (this appears to be a detail too often
> >> forgotten) ?
> >> > See if you have a MALLOC_CHECK_ env variable set and then read
> >> > malloc's man page.
> >> > Regards,
> >> > Umberto
> >> > On 6/26/05, Geo-IT GmbH <info at geo-it.com> wrote:
> >> >> Dear experts,
> >> >> When trying to fetch a shapeObj after a queryByPoint using the shapeindex
> >> >> and
> >> >> tileindex from the resultCache in a Java mapscript program I get the
> >> >> following
> >> >> error terminating the whole VM:
> >> >> *** glibc detected *** malloc(): memory corruption: 0x08314ed0 ***
> >> >> ./runshapetest40.sh: line 13: 26946 Aborted java ShapeObjTest40 $mapfile
> >> >> $layername
> >> >> The program was:
> >> >> // Standard imports
> >> >> import java.io.*;
> >> >> import java.util.*;
> >> >> import java.text.*;
> >> >> import edu.umn.gis.mapscript.*;
> >> >> public class ShapeObjTest {
> >> >>         String mapFile = null;
> >> >>         String layerName = null;
> >> >> static {
> >> >>         try {
> >> >>                 System.loadLibrary("mapscript");
> >> >>                 System.out.println("Mapscript lib loaded");
> >> >>         } catch (UnsatisfiedLinkError e) {
> >> >>                 e.printStackTrace();
> >> >>                 System.exit(1);
> >> >>         public ShapeObjTest() {
> >> >>         protected static void log(String msg) {
> >> >>                 System.out.println(msg);
> >> >>         protected static void usage() {
> >> >>                 System.out.println("USAGE: ShapeObjTest <mapfile>
> >> >> <layername>");
> >> >>         public static void main (String args[] ) {
> >> >>                 if (args == null || args.length < 2) {
> >> >>                         usage();
> >> >>                         System.exit(1);
> >> >>                 String mapFile = args[0];
> >> >>                 String layerName = args[1];
> >> >>         try {
> >> >>                 log("Creating map");
> >> >>                 mapObj map = new mapObj(mapFile);
> >> >>                 layerObj l = map.getLayerByName(layerName);
> >> >>                 l.open();
> >> >>                 log("Fetching shapeObj shapeindex 1 tileindex -1");
> >> >>                 shape = l.getFeature(1,-1);
> >> >>                 l.close();
> >> >>                 log("Fetch successful");
> >> >>         } catch (Exception ie) {
> >> >>                 ie.printStackTrace();
> >> >>                 System.exit(1);
> >> >> The log shows:
> >> >> Creating map
> >> >> Then the error appears on the console.
> >> >> I use mapserver 4.6.0.
> >> >> This is the mapfile: (It's the one from Itasca demo, but only with layer
> >> >> airports)
> >> >> MAP
> >> >>   # Start of map file
> >> >>   NAME "DEMO"
> >> >>   STATUS ON
> >> >>   EXTENT 388107.634400379 5203120.88405952 500896.339019834
> >> 5310243.30613897
> >> >>   SIZE 600 600
> >> >>   SHAPEPATH "data"
> >> >>   IMAGECOLOR 255 255 255
> >> >>   UNITS METERS
> >> >>   # you may need to change this to match your MapServer build
> >> >>   #IMAGETYPE PNG
> >> >>   # Projection definition, consult the PROJ.4 documentation for parameter
> >> >> discussion
> >> >>   PROJECTION
> >> >>     "proj=utm"
> >> >>     "ellps=GRS80"
> >> >>     "zone=15"
> >> >>     "north"
> >> >>     "no_defs"
> >> >> #  OR:
> >> >>   #  "init=epsg:26915"
> >> >>   END
> >> >>   # Start of web interface definition (including WMS enabling metadata)
> >> >>   WEB
> >> >>     MINSCALE 1000
> >> >>     MAXSCALE 1550000
> >> >>     IMAGEPATH "/tmp"
> >> >>     IMAGEURL "/tmp"
> >> >>     HEADER "demo_header.html"
> >> >>     FOOTER "demo_footer.html"
> >> >>     TEMPLATE "demo.html"
> >> >>     METADATA
> >> >>       "WMS_TITLE"    "UMN MapServer Itasca Demo"
> >> >>       "WMS_ABSTRACT"    "This is the UMN MapServer demonstration
> >> application
> >> >> for Itasca County located in north central Minnesota."
> >> >>       "WMS_ACCESSCONSTRAINTS"    "none"
> >> >>       "WMS_ONLINERESOURCE"
> >> >> "http://localhost.localdomain/mapserver_demos/itasca/demo_init.html"
> >> >>       "WMS_SRS"    "EPSG:26915"
> >> >>     END
> >> >>   END
> >> >>   # Start of reference map
> >> >>   REFERENCE
> >> >>     STATUS ON
> >> >>     IMAGE "graphics/reference.gif"
> >> >>     SIZE 120 120
> >> >>     EXTENT 393234.393701263 5205405.16440722 495769.579718949
> >> >> 5307959.02579127
> >> >>     COLOR -1 -1 -1
> >> >>     OUTLINECOLOR 255 0 0
> >> >>   END
> >> >>   QUERYMAP
> >> >>     STATUS ON
> >> >>     SIZE 200 200
> >> >>     COLOR 255 0 0
> >> >>     STYLE HILITE
> >> >>   END
> >> >>   # Start of legend
> >> >>   LEGEND
> >> >>     STATUS ON
> >> >>     KEYSIZE 18 12
> >> >>     LABEL
> >> >>       TYPE BITMAP
> >> >>       SIZE MEDIUM
> >> >>       COLOR 0 0 89
> >> >>     END
> >> >>   END
> >> >>   # Start of scalebar
> >> >>   SCALEBAR
> >> >>     STATUS ON
> >> >>     COLOR 0 102 102
> >> >>     OUTLINECOLOR 102 255 0
> >> >>     BACKGROUNDCOLOR 255 51 102
> >> >>     TRANSPARENT OFF
> >> >>     UNITS MILES
> >> >>     INTERVALS 1
> >> >>     SIZE 80 2
> >> >>     STYLE 1
> >> >>     INTERLACE ON
> >> >>     LABEL
> >> >>       TYPE BITMAP
> >> >>       SIZE MEDIUM
> >> >>       COLOR 0 0 0
> >> >>     END
> >> >>   END
> >> >>   # Start of symbol definitions (we're only using a few)
> >> >>   SYMBOL
> >> >>     NAME "circle"
> >> >>     TYPE ELLIPSE
> >> >>     FILLED TRUE
> >> >>     POINTS
> >> >>        1 1
> >> >>     END
> >> >>   END
> >> >>   # Start of layer definitions
> >> >>   LAYER
> >> >>     NAME "airports"
> >> >>     STATUS OFF
> >> >>     DATA "airports"
> >> >>     TYPE POINT
> >> >>     TOLERANCE 5
> >> >>     HEADER "airports_header.html"
> >> >>     FOOTER "airports_footer.html"
> >> >>     TEMPLATE "ttt.html"
> >> >>     METADATA
> >> >>       "WMS_TITLE"    "Airports"
> >> >>       "WMS_ABSTRACT"    "Airport runways for Itasca County."
> >> >>     END
> >> >>     CLASS
> >> >>       NAME "Airports"
> >> >>       SYMBOL "circle"
> >> >>       COLOR 128 255 164
> >> >>       SIZE 7
> >> >>       TEMPLATE "airports.html"
> >> >>     END
> >> >>   END
> >> >> Any help would be greatly appreciated.
