GRIDS and Graticule
John Novak
hetzerrr at GMAIL.COM
Tue Jun 28 15:07:19 EDT 2005
Please attach the .map file you're using
On 6/28/05, François TOURDE <fr-ms at tourde.org> wrote:
> Le 12962ième jour après Epoch,
> Brent Fraser écrivait:
> > François,
> > Here's the documentation explanation, along with some of my notes on the
> > parameters:
> Many thanks for your reply.
> > MINARCS [double]
> > The minimum number of arcs to draw.
> > The minimum number of graticule lines to draw on the map. Use this
> > parameter to get more lines.
> > MAXARCS [double]
> > The maximum number of arcs to draw.
> > The maximum number of graticule lines to draw on the map. Use this
> > parameter to get fewer lines.
> Thanks for the explanation. Unfortunately it is what I have
> understood. And it doesn't works for me.
> When I use "MAXARCS 10" for example, and zooming out on the map, there
> is lot (more than 10) graticule lines.
> I use MAPSERVER V4.4.1 (stock Debian packets)
> > MININTERVAL [double]
> > MAXINTERVAL [double]
> Idem.
> > MINSUBDIVIDE [double]
> > MAXSUBDIVIDE [double]
> Not yet used... I'm waiting for previous parms to work. ;)
> Your aims are high, and you are capable of much.
