error when connecting to demo
Emil Zegers taatuut at PLANET.NL
Thu Jun 30 13:49:03 EDT 2005
I believe with the new 4.6 version of MapServer all string values
should be enclosed with double quotes.
You'll probably find a lot of demos with 'old' .map files that need to
be updated for this.
Regards,
Emil
----- Oorspronkelijk bericht -----
Van: Philip Dillon-Thiselton <dibblethewrecker at JIWE.ORG>
Datum: donderdag, juni 30, 2005 6:50 pm
Onderwerp: Re: [UMN_MAPSERVER-USERS] error when connecting to demo
> OK - i figured out that
> WMS_ACCESSCONSTRAINTS none
> should be
> WMS_ACCESSCONSTRAINTS "none"
> That should probably be changed in the .zip archive.  After a bit of
> jiggling with the index.html file it is all working.
> Thanks for the .map file pointer
> Phil
> Philip Dillon-Thiselton wrote:
> > Ok - here is the output below from the itasca.map file - this was
> > unchanged from the version in the .zip file until i just changed
the
> > WMS_ONLINERESOURCE to see if that fixed it - it did not.
> > I am using the latest Mapserver and latest demo files from
> > workshop.zip - they are built from src by me in linux.
> >    METADATA
> >      WMS_TITLE "UMN MapServer Itasca Demo"
> >      WMS_ABSTRACT "This is a UMN MapServer application for Itasca
> > County located in north central Minnesota."
> > 73      WMS_ACCESSCONSTRAINTS none
> >      # change this value to match your setup
> >      WMS_ONLINERESOURCE "http://heaton/mapserver_demo/index.html"
