Help installing Windows binaries
Ken Lord kenlord at GMAIL.COM
Sun Mar 6 23:32:24 EST 2005
Hi Jack,
There's been a few people in the last couple weeks, including myself
that have had problems with the 4.4.1 windows binaries at the
mapserver homepage that seems to be related to the manner in which it
was compiled.  The problem goes beyond the usual dll problems that are
associated with the error message you received.
If you still have problems making mapserver run,  download 4.4.1 from:
maptools.org/dl
This version has a larger exe that is less dependant on external dll's
and worked fine for myself and for the other people that had the
issues.
Use the mapserv.exe plus the dll's that are found within the various
zip files within the main zip file you download from them.
Have fun,
Ken Lord
Vancouver BC
On Sun, 6 Mar 2005 18:25:56 +0800, Jack Ling <fly2moon2 at gmail.com> wrote:
> Hi Bart,
> Thanks for your insights.
> Finally found that 2 dll files are missing: msvcr70.dll & msvcr71.dll.
> I've to download it separately from Internet and put them to
> c:\windows\system32 then I see the expected msg:
> "No query information to decode. QUERY_STRING is set, but empty."
> best regards,
> Jack Ling
> On Sun, 06 Mar 2005 11:03:51 +0100, Bart van den Eijnden
> <bartvde at xs4all.nl> wrote:
> > Hi Jack,
> > that usually means one of the dll's can't be found. Where did you put your
> > dll's for mapserver?
> > Can you do mapserv.exe -v in a command prompt? Or use a tool like
> > Dependency Walker to find out what's missing.
> > If you don't have access to the server to do that, try the maptools.org
> > binaries at:
> > http://maptools.org/php_mapscript/index.phtml?page=downloads.html
> > Best regards,
> > Bart
> > On Sun, 6 Mar 2005 15:25:51 +0800, Jack Ling <fly2moon2 at GMAIL.COM> wrote:
> > > Hi All,
> > > I got the windows binaries from:
> > > http://mapserver.gis.umn.edu/win32binaries.html
> > > and installed on My Windows XP SP1 PC.
> > > I followed the README installation procedures. I've tried 1st using
> > > Apache server using port 81 for testing:
> > > http://localhost:81/cgi-bin/mapserv.exe
> > > -> it has internal server error:
> > > Internal Server Error
> > > The server encountered an internal error or misconfiguration and was
> > > unable to complete your request.
> > > [error message end]
> > > -> in its error log, the message appears:
> > > Premature end of script headers: mapserv.exe
> > > [error message end]
> > > Then, i tried on IIS using port 80:
> > > http://localhost/cgi-bin/mapserv.exe
> > > -> it has CGI error:
> > > CGI Error
> > > The specified CGI application misbehaved by not returning a complete
> > > set of HTTP headers. The headers it did return are:
> > > [error message end]
> > > I don't know what's the problem? I've no problem using my configured
> > > Webservers to access other testing pages.
> > > Any help?
> > > best regards,
> > > Jack Ling
> > Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
