Python Mapscript QueryByPoint
Sean Gillies
sgillies at FRII.COM
Wed Mar 9 09:56:33 EST 2005
Jon,
Check the querying howto under mapscript/doc. I am hosting an HTML
version of the same doc at
http://users.frii.com/sgillies/projects/mapscript/querying-HOWTO.html
cheers,
Sean
On Mar 9, 2005, at 7:52 AM, Jon Saints wrote:
> Thanks to the list,
> adding a blank template to my mapfile worked like a
> charm. Now I can access the resultset and call the
> function results.getResult(0). this object appears to
> only have a memeber variable called shapeindex.
> how can I use this information to get the other
> attribute fields from the dbf information in the shape
> file?
> thanks in advance
> Jon
> --- Eric Bridger <eric at GOMOOS.ORG> wrote:
>> On Tue, 2005-03-08 at 07:49, Jon Saints wrote:
>>> I am having trouble querying a flat shapefile
>> using
>>> python mapscript with the queryByPoint function.
>>> My getResults always equals None. I believe my
>> trouble
>>> has something to do with: (from the swig
>>> documentation) "A query will not set results for a
>>> layer with a NULL 'template' attribute."
>>> I have tried using both map and pixel coords for
>> the
>>> point object. Both point objects, I am sure
>> intersect
>>> a feature of layer 0 on my map.
>>> I receive the error:
>>> "'NoneType' object has no attribute 'numresults'"
>>> My code:
>>> #Map coords
>>> #click = pointObj()
>>> #click.x = 77.01
>>> #click.y = 38.89
>>> #pixel Coords
>>> click = pointObj()
>>> click.x = 300
>>> click.y = 200
>>> myMap.getLayer(0).queryByPoint( myMap, click,
>>> MS_SINGLE, 10.0 )
>>> results = myMap.getLayer(0).getResults()
>>> output = results.numresults
>>> excerpt from My mapfile:
>>> LAYER
>>> NAME dcdem2000
>>> TYPE POLYGON
>>> STATUS ON
>>> METADATA
>>> desc "Census Blocks"
>>> logo "test.jpg"
>>> END
>>> DATA "/home/jons/Data/DC/created/dcdem2000"
>>> CLASS
>>> NAME "Census Blocks 2000"
>>> COLOR 225 225 225
>>> OUTLINECOLOR 100 100 100
>>> END
>>> END
>> In your LAYER add TEMPLATE "ttt".
>> That will define a template and allow queries even
>> though you don't use
>> it.
>> Eric
Sean Gillies
sgillies at frii dot com
