MouseOver & Coordinates
Martin Weinelt
mweinelt at PLANIGLOBE.COM
Thu Mar 10 08:04:05 EST 2005
On Thursday 10 March 2005 13:06, Stefan Schwarzer wrote:
> Thanks Martin for that. The only thing I am not sure about is how
the
> javascript variable, which holds the information about the pixel
size,
> should be called. How does this variable get into the Javascript
> functions?
> Thanks for your help - and congratulations to your planiglobe.com
site.
> Looks really neat!!
> Stef
If your server delivers the entire interface (page) on every map
generation, simply set the javascript obj or variable at generation
time.
With the last projects I send the core map elements generated (map,
ref, scale, etc) to a hidden iframe which calls a function in the
parent document onload to parse/copy the new content.
Part of the document in the iframe could be a good ol' HTML-form
holding the values.
With Perl mapScript one part of the page sent back could look like:
print <<"EOFORM";
<form name="params">
<input type="hidden" name="csz" value="$m->{cellsize}">
</form>
EOFORM
where $m is the Perl mapScript map object you are working on.
With CGI mapserver you would put a similar form into the template,
but since the cell size is not an available CGI variable - as far as I
know - you must pass the mapextent.
<input type="hidden" name="mext" value="[MAPEXT]">
</form>
The <body> tag of the doc in the iframe could be:
<body onload="parent.parseIframe();">
and the function in the parent doc could look like:
function parseIframe() {
var paramsForm= parent.frames[0].document.forms["params"],
myMap.mapext = paramsForm.elements["mext"].value;
// or myMap.csz=paramsForm.elements["csz"].value;
As I said before, if you use mapextent you calc cell size yourself.
Cheers, Martin
> > On Thursday 10 March 2005 11:07, Stefan Schwarzer wrote:
> >> Hi,
> >> I would like to display the coordinates in a corner of the map,
when a
> >> user moves the mouse over it. Is there any Javascript (or Java)
code
> >> out there that would do this?
> >> Thanks for any suggestions.
> >> Stef
> > Stefan,
> > you need to know the pixel size of your map image in map units
(DD,
> > meters,..).
> > using MapScript you can pass this value along with every new map
> > generated
> > as a (hidden) value and set a javascript object or variable to
this
> > value.
> > With mapserver CGI you must calculate this value by image size and
map
> > extent
> > yourself.
> > Next you define an eventhandler for the mouseover event of your
map
> > image,
> > for instance:
> > function MapElmOverHndl(e) {
> > var imgOrig = theMap.getorig();
> > var posx = ((e.offsetX * theMap.getcsz())+imgOrig[0]);
> > var posy = (((400-e.offsetY) * theMap.getcsz())+imgOrig[1]));
> > Dspl.innerHTML=posx+' '+posy;
> > 'theMap.getorig()': returns minx, miny (mapunits) of the current
> > 'theMap.getcsz()': returns the cellsize (pixelsize) in mapunits
> > '400' is the image height in pixels
> > 'Dspl' is a document element like <p>, <td>, <div> or some such.
> > Once you got the handler you add this event handler to your map
image.
> > If your map image got an id of - say - 'myMap':
> > for DOM-Browsers you type:
document.getElementById('myMap').addEventListener("mousemove",MapElmOve
> > rHndl , false)
> > for IE6 you type:
> > document.all['myMap''].attachEvent("onmousemover",
MapElmOverHndl);
> > A cross browser solution could look similar to:
> > var d= document;
> > if (!d.getElementById && d.all) d.getElementById = new
Function('id',
> > 'return d.all[id]');
> > function X_addEventListener(elm, evt, lstnr, useCapture) {
> > (! elm.addEventListener && d.all)? elm.attachEvent('on'+evt,
lstnr)
> > : elm.addEventListener(evt, lstnr, useCapture);
> > Now you add the listener by:
> > myMapElm= d.getElementById('myMap');
> > X_addEventListener(myMapElm ,"mousemove", MapElmOverHndl, false);
> > Cheers, Martin
> _______________________________________
> Stefan Schwarzer
> GIS & Data Management
> UNEP/DEWA/GRID-Geneva
> Chemin des Anemones 11
> CH - 1219 Chatelaine
> Switzerland
> Tel: (+41) 22.917.83.49
> Fax: (+41) 22.917.80.29
> Internet: http://geodata.grid.unep.ch/
--- Martin Weinelt
--- kk+w - digital cartography
--- Kiel, Germany
--- Tel: +49.431.5791165
--- http://www.planiglobe.com
