how to use java mapscript in tomcat4/jspenvironment?
Umberto Nicoletti unicoletti at PROMETEO.IT
Wed Mar 16 07:01:03 EST 2005
When you built java mapscript did you run make test at the end?
Did you install tomcat yourself (grabbed binary for jakarta.apache.org)
or installed the version that came with your distro?
If you did the latter the I suggest you should experiment with a binary
release from the jakarta site.
Umberto
On Wed, 2005-03-16 at 19:44 +0800, wlx wrote:
> Hi,
>     My java version is 1.4.2, the result of run java -version is:
> java version "1.4.2_07"
> Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2_07-b05)
> Java HotSpot(TM) Client VM (build 1.4.2_07-b05, mixed mode)
>     And I am sorry for that I forget to cc the mail to the mail list.
> Liangxu Wang
> > Please reply to the ml too next time.
> > Th error you are getting is relative to the security policy
> > of the jvm that forbids the servlet to invoke
> > system.loadLibrary. This is rather unusual, please post the
> > output of the following command:
> > java -version
> > and the tomcat version (seems 4.1).
> > Regards,
> > Umberto
> > On Wed, 2005-03-16 at 09:23 +0800, wlx wrote:
> > >  Hi Umberto,
> > >        This is my test.jsp content:
> > > <%@ page language="java" import="edu.umn.gis.mapscript.*"
> > %> <%@ page
> > > import="java.lang.System" %> <%  System.loadLibrary("mapscript");
> > > mapObj map = new
> > > mapObj("/usr/share/tomcat4/webapps/ROOT/test/test.map");
> > > // imageObj img = map.draw();
> > > // img.save("test.gif",map);
> > > // webObj web = new mapObj(web);
> > > <HTML>
> > > <BODY>
> > > Hello! The image is :
> > > //  String test1=img.getImageurl();
> > >    out.println("hello,world");
> > > </BODY>
> > > </HTML>
> > >    The error message is :
> > >          The server encountered an internal error () that
> > prevented it
> > > from fulfilling this request.
> > >    And you can you view the detailed error message here:
> > > http://210.77.68.214:8180/test.jsp
> > >        I have tested with comment the new mapObj
> > sentence,thus it is
> > > working.
> > >      Best regard,
> > >      Yours sincerely,
> > > Liangxu Wang
> > > > tomcat4/jsp environment?
> > > > On Tue, 2005-03-15 at 10:37 +0800, wlx wrote:
> > > > > Hi list,
> > > > >     I have compiled java mapscript with mapserver 4.4.1 in my
> > > > > system,but I don't know how to use it. My system is Debian
> > > > sarge,and I
> > > > > compiled mapserver
> > > > > with:
> > > > >   ./configure --with-gd=/usr --with-gdal=/usr/bin/gdal-config
> > > > > --with-ogr --with-proj --with-threads
> > > > >   make
> > > > >   cd mapscript/java
> > > > >   make
> > > > >   make test
> > > > >   cp *.so /usr/lib/jni/
> > > > >   cp *.jar /usr/share/tomcat4/common/lib
> > > > > Are there something wrong? I even copy the jar file to tomcat4
> > > > > webapps/ROOT/WEB-INF/lib/.
> > > > > But when I want to create a simple test jsp file with java
> > > > mapscript,
> > > > > just create a new mapObj,errors happened.
> > > > What kind of errors do you get?
> > > > Umberto
> > > > > So is there a simple introduction with java mapscript or a
> > > > simple example?
> > > > >    Best wish,
> > > > > Sincerely yours,
> > > > > Liangxu Wang
> > > > Umberto Nicoletti                          |   We are
> > Pentium of Borg.
> > > > +390415701366   unicoletti at prometeo.it     |   Division is futile.
> > > > Prometeo S.R.L. The Software Experience    |   You will be
> > > > approximated.
> > Umberto Nicoletti                          |   We are Pentium of Borg.
> > approximated.
Prometeo S.R.L. The Software Experience    |   You will be approximated.
