how to use java mapscript intomcat4/jspenvironment?
wlx wlx at MYGIS.ORG
Wed Mar 16 07:08:34 EST 2005
> When you built java mapscript did you run make test at the end?
> Did you install tomcat yourself (grabbed binary for
> jakarta.apache.org) or installed the version that came with
> your distro?
    Yes,I have run the make test command, and it is successful executed, and
as my system is Debian sarge, I installed the tomcat4 with simple command:
apt-get install tomcat4.
> If you did the latter the I suggest you should experiment
> with a binary release from the jakarta site.
ok,I will try it.. Thank you very much.
> Umberto
> On Wed, 2005-03-16 at 19:44 +0800, wlx wrote:
> > Hi,
> >     My java version is 1.4.2, the result of run java -version is:
> > java version "1.4.2_07"
> > Java(TM) 2 Runtime Environment, Standard Edition (build
> 1.4.2_07-b05)
> > Java HotSpot(TM) Client VM (build 1.4.2_07-b05, mixed mode)
> >     And I am sorry for that I forget to cc the mail to the
> mail list.
> > Liangxu Wang
> > > Please reply to the ml too next time.
> > > Th error you are getting is relative to the security
> policy of the
> > > jvm that forbids the servlet to invoke
> system.loadLibrary. This is
> > > rather unusual, please post the output of the following command:
> > > java -version
> > > and the tomcat version (seems 4.1).
> > > Regards,
> > > Umberto
> > > On Wed, 2005-03-16 at 09:23 +0800, wlx wrote:
> > > >  Hi Umberto,
> > > >        This is my test.jsp content:
> > > > <%@ page language="java" import="edu.umn.gis.mapscript.*"
> > > %> <%@ page
> > > > import="java.lang.System" %> <%
> System.loadLibrary("mapscript");
> > > > mapObj map = new
> > > > mapObj("/usr/share/tomcat4/webapps/ROOT/test/test.map");
> > > > // imageObj img = map.draw();
> > > > // img.save("test.gif",map);
> > > > // webObj web = new mapObj(web);
> > > > <HTML>
> > > > <BODY>
> > > > Hello! The image is :
> > > > //  String test1=img.getImageurl();
> > > >    out.println("hello,world");
> > > > </BODY>
> > > > </HTML>
> > > >    The error message is :
> > > >          The server encountered an internal error () that
> > > prevented it
> > > > from fulfilling this request.
> > > >    And you can you view the detailed error message here:
> > > > http://210.77.68.214:8180/test.jsp
> > > >        I have tested with comment the new mapObj
> > > sentence,thus it is
> > > > working.
> > > >      Best regard,
> > > >      Yours sincerely,
> > > > Liangxu Wang
> > > > > tomcat4/jsp environment?
> > > > > On Tue, 2005-03-15 at 10:37 +0800, wlx wrote:
> > > > > > Hi list,
> > > > > >     I have compiled java mapscript with mapserver
> 4.4.1 in my
> > > > > > system,but I don't know how to use it. My system is Debian
> > > > > sarge,and I
> > > > > > compiled mapserver
> > > > > > with:
> > > > > >   ./configure --with-gd=/usr
> --with-gdal=/usr/bin/gdal-config
> > > > > > --with-ogr --with-proj --with-threads
> > > > > >   make
> > > > > >   cd mapscript/java
> > > > > >   make
> > > > > >   make test
> > > > > >   cp *.so /usr/lib/jni/
> > > > > >   cp *.jar /usr/share/tomcat4/common/lib
> > > > > > Are there something wrong? I even copy the jar file
> to tomcat4
> > > > > > webapps/ROOT/WEB-INF/lib/.
> > > > > > But when I want to create a simple test jsp file with java
> > > > > mapscript,
> > > > > > just create a new mapObj,errors happened.
> > > > > What kind of errors do you get?
> > > > > Umberto
> > > > > > So is there a simple introduction with java mapscript or a
> > > > > simple example?
> > > > > >    Best wish,
> > > > > > Sincerely yours,
> > > > > > Liangxu Wang
> > > > > Umberto Nicoletti                          |   We are
> > > Pentium of Borg.
> > > > > +390415701366   unicoletti at prometeo.it     |
> Division is futile.
> > > > > Prometeo S.R.L. The Software Experience    |   You will be
> > > > > approximated.
> Pentium of Borg.
> > > +390415701366   unicoletti at prometeo.it     |   Division is futile.
> > > approximated.
> Umberto Nicoletti                          |   We are Pentium of Borg.
> approximated.
