Problems reading a TIF file (newbie question)
Brent Fraser
bfraser at GEOANALYTIC.COM
Tue Mar 22 13:20:16 EST 2005
Ray,
Try removing the PROJECTION definition from your map file. Since you are
not moving data from one world coordinate system to another, the PROJECTION
definition is not needed.
But if you want to do coordinate system stuff, likely the correct
PROJECTION definition (for the tiff file) would look like:
PROJECTION
"proj=tmerc"
"ellps=mod_airy"
"lon_0=-8"
"lat_0=53.5"
"k=1.000035"
"x_0=200000"
"y_0=250000"
END
Brent Fraser
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Tuesday, March 22, 2005 9:03 AM
Subject: [UMN_MAPSERVER-USERS] Problems reading a TIF file (newbie question)
> I am having problems displaying a TIF file using PHP mapscript, I suspect
> that the problem lies in the map file.
> gdalinfo PAGE48.TIF (name of the file) gives:
> Driver: GTiff/GeoTIFF
> Size is 4724, 6300
> Coordinate System is `'
> Metadata:
> TIFFTAG_DOCUMENTNAME=JOB_NAME
TIFFTAG_IMAGEDESCRIPTION=DKB200:[OS50000.DUBGUIDE_4TH_MAPS]PAGE_CLIP_48.TIF;
> TIFFTAG_SOFTWARE=Barco Graphics - V9.2
> TIFFTAG_XRESOLUTION=600
> TIFFTAG_YRESOLUTION=600
> TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
> Corner Coordinates:
> Upper Left ( 0.0, 0.0)
> Lower Left ( 0.0, 6300.0)
> Upper Right ( 4724.0, 0.0)
> Lower Right ( 4724.0, 6300.0)
> Center ( 2362.0, 3150.0)
> Band 1 Block=4724x8 Type=Byte, ColorInterp=Palette
> Color Table (RGB with 256 entries)
> 0: 255,255,255,255
> 1: 59,43,47,255
> 2: 0,137,159,255
> <...cut...>
> 254: 255,255,255,255
> 255: 255,255,255,255
> I used the TAB file to get the map EXTENT and projection:
> $ cat Page48.TAB
> !table
> !version 300
> !charset WindowsLatin1
> Definition Table
> File "./PAGE48.TIF"
> Type "RASTER"
> (318000,232000) (1,0) Label "Pt 1",
> (321000,232000) (4723,0) Label "Pt 2",
> (321000,228000) (4723,6296) Label "Pt 3",
> (318000,228000) (1,6295) Label "Pt 4"
> CoordSys Earth Projection 8, 42, "m", -8, 53.5, 1.000035, 200000, 250000
> Units "m"
> I also have a TFW file:
> $ cat Page48.TFW
> 0.635324015247776
> 0
> 0
> -0.635324015247776
> 317999.682337992
> 231999.682337992
> My MAP file looks like this:
> MAP
> NAME PAGE48
> STATUS ON
> SIZE 472 630
> IMAGETYPE PNG
> EXTENT 318000 228000 321000 232000
> UNITS METERS
> FONTSET "./fonts/fonts.list"
> SHAPEPATH "./data/"
> IMAGECOLOR 15 158 120
> PROJECTION
> "proj=utm"
> "ellps=mod_airy"
> "lon_0=-8"
> "lat_0=53.5"
> END
> WEB
> IMAGEPATH "/var/www/html/mapscript/gmap-ms40/greenmap/test/"
> IMAGEURL "/mapscript/gmap-ms40/greenmap/test/"
> END
> LAYER
> DATA "./data/PAGE48.TIF"
> TYPE RASTER
> END
> LAYER
> NAME "test text"
> STATUS DEFAULT
> TRANSFORM FALSE
> TYPE ANNOTATION
> FEATURE
> POINTS
> 60 10
> END
> TEXT "This text should appear at the top of the image."
> END
> CLASS
> LABEL
> TYPE truetype
> FONT arial
> SIZE 12
> POSITION CR
> COLOR 0 0 0
> END
> END
> END
> END
> And my code looks like this:
> <?php
> dl ("php_mapscript.so");
> ms_ResetErrorList();
> $map = ms_newMapObj ("greenmap.map");
> $image = $map->draw();
> $image_url = $image->saveWebImage(MS_PNG, 0, 0, -1);
> $error = ms_GetErrorObj ();
> print ("$error->code");
> while ($error && $error->code != MS_NOERR)
> printf ("Error in %s: %s<br>\n", $error->routine, $error->message);
> $error = $error->next();
> echo "<img src=$image_url width=$map->width height=$map->height>";
> I get a nice green background with the text as I expected, but I'd really
> like to see the map too...
> Any ideas about what I'm doing wrong gratefully received.
> Thanks,
> Ray
