WFS bug? - multiple layers from same service
Fawcett, David
David.Fawcett at STATE.MN.US
Tue Mar 29 16:22:40 EST 2005
Elizabeth,
I ran into a similar glitch, except that all three layers were polys and they were added dependent on REQUIRES. They all took on the style of the first layer.
I believe that I was using 4.2.3
I will try to dig up the Map File.
David.
David Fawcett
Minnesota Office of Environmental Assistance
david.fawcett at moea.state.mn.us
651.215.0200
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On Behalf Of Godwin, Elizabeth
Sent: Tuesday, March 29, 2005 3:00 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] WFS bug? - multiple layers from same service
Attached is the map file. The services are all internal, so don't bother trying to connect to them. The data being served via WFS is based on shapfiles, the map file is almost identical to this one, minus the connection string, metadata info is different.
Liz
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Ethan Alpert
Sent: March 29, 2005 3:29 PM
What's the mapfile look like? Is there a chance that there are name colisions between the layers?
-e
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Godwin, Elizabeth
Sent: Tuesday, March 29, 2005 1:24 PM
Subject: [UMN_MAPSERVER-USERS] WFS bug? - multiple layers from same service
I'm experiencing a wierd phenomenon with a mapfile i am working with. It's a bit of a unique case in that the map is composed of 3 layers, all WFS layers coming from the same service.
The odd thing is...when I do this... only the FIRST layer in the map is drawn, but using the class info from the LAST layer of this service. If I draw the middle layer from a different service...the same is true, except that middle layer draws normal. So FIRST is drawing with THIRD styling, on top of SECOND that has it's own styling.
In this case, it's polygons, lines and points, so the polygons are drawing with point symbology on top of lines. Or if all are coming from the same service, all that is drawn is polygins with point symbology. The last two layers are not drawn.
I'm working with a cvs version from a month ago or so, but I also tested against 4.4.0
Shall I post a bug? I'm asking first in case I've overlooked something silly.
Liz Godwin
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050329/f975e397/attachment.html
