WFS bug? - multiple layers from same service
Bart van den Eijnden
bartvde at XS4ALL.NL
Wed Mar 30 12:44:44 EST 2005
Hi Liz,
could this have something to do with the WFS client caching mechanism? But
if I look at your MAP file you don't specify the wfs_request_method GET
metadata so if your Mapserver is new enough it should default to POST, and
POST uses no cache at the moment.
How many GML files do you see coming into your IMAGEPATH directory in the
first case you describe where all layers come from the same WFS service?
Best regards,
Bart
On Tue, 29 Mar 2005 15:24:25 -0500, Godwin, Elizabeth <Godwinl at AGR.GC.CA>
wrote:
> I'm experiencing a wierd phenomenon with a mapfile i am working with.
> It's a bit of a unique case in that the map is composed of 3 layers, all
> WFS layers coming from the same service.
> The odd thing is...when I do this... only the FIRST layer in the map is
> drawn, but using the class info from the LAST layer of this service. If
> I draw the middle layer from a different service...the same is true,
> except that middle layer draws normal. So FIRST is drawing with THIRD
> styling, on top of SECOND that has it's own styling.
> In this case, it's polygons, lines and points, so the polygons are
> drawing with point symbology on top of lines. Or if all are coming from
> the same service, all that is drawn is polygins with point symbology.
> The last two layers are not drawn.
> I'm working with a cvs version from a month ago or so, but I also tested
> against 4.4.0
> Shall I post a bug? I'm asking first in case I've overlooked something
> silly.
> Liz Godwin
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
