WFS bug? - multiple layers from same service
Godwin, Elizabeth Godwinl at AGR.GC.CA
Wed Mar 30 13:03:55 EST 2005
Hi Bart,
There was only 1 gml file when I call the map with all three layers
coming from the same source.  Inside the gml, there is only gml for the
one layer.
When I do it again with the middle layer coming from a different source,
there are two gml.  I didn't look, but I suspect one for the first
layer, one for the second.
Cheers,
Liz
> -----Original Message-----
> From: Bart van den Eijnden [mailto:bartvde at xs4all.nl]
> Sent: March 30, 2005 12:45 PM
> To: Godwin, Elizabeth; MAPSERVER-USERS at lists.umn.edu
> Subject: Re: [UMN_MAPSERVER-USERS] WFS bug? - multiple layers
> from same service
> Hi Liz,
> could this have something to do with the WFS client caching
> mechanism? But
> if I look at your MAP file you don't specify the
> wfs_request_method GET
> metadata so if your Mapserver is new enough it should default
> to POST, and
> POST uses no cache at the moment.
> How many GML files do you see coming into your IMAGEPATH
> directory in the
> first case you describe where all layers come from the same
> WFS service?
> Best regards,
> Bart
> On Tue, 29 Mar 2005 15:24:25 -0500, Godwin, Elizabeth
> <Godwinl at AGR.GC.CA>
> wrote:
> > I'm experiencing a wierd phenomenon with a mapfile i am
> working with.
> > It's a bit of a unique case in that the map is composed of
> 3 layers,
> > all WFS layers coming from the same service. The odd thing
> is...when I
> > do this...  only the FIRST layer in the map is drawn, but using the
> > class info from the LAST layer of this service.  If I draw
> the middle
> > layer from a different service...the same is true, except
> that middle
> > layer draws normal.  So FIRST is drawing with THIRD
> styling, on top of
> > SECOND that has it's own styling. In this case, it's
> polygons, lines
> > and points, so the polygons are drawing with point
> symbology on top of
> > lines.  Or if all are coming from the same service, all
> that is drawn
> > is polygins with point symbology. The last two layers are not drawn.
> > I'm working with a cvs version from a month ago or so, but
> I also tested
> > against 4.4.0
> > Shall I post a bug?  I'm asking first in case I've
> overlooked something
> > silly.
> > Liz Godwin
> Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
