WFS bug? - multiple layers from same service
Bart van den Eijnden bartvde at XS4ALL.NL
Wed Mar 30 13:05:05 EST 2005
Hi Liz,
Just thinking out loud, that does sound like cache to me :)
Do you have DEBUG ON on your layer and MS_ERRORFILE set? That could
provide more info for this issue, there is a statement in there when
something is read from cache if I remember correctly.
Can you specify explicitly wfs_request_method "POST" on all the layers to
test?
Best regards,
Bart
On Wed, 30 Mar 2005 13:03:55 -0500, Godwin, Elizabeth <Godwinl at AGR.GC.CA>
wrote:
> Hi Bart,
> There was only 1 gml file when I call the map with all three layers
> coming from the same source.  Inside the gml, there is only gml for the
> one layer.
> When I do it again with the middle layer coming from a different source,
> there are two gml.  I didn't look, but I suspect one for the first
> layer, one for the second.
> Cheers,
> Liz
>> -----Original Message-----
>> From: Bart van den Eijnden [mailto:bartvde at xs4all.nl]
>> Sent: March 30, 2005 12:45 PM
>> To: Godwin, Elizabeth; MAPSERVER-USERS at lists.umn.edu
>> Subject: Re: [UMN_MAPSERVER-USERS] WFS bug? - multiple layers
>> from same service
>> Hi Liz,
>> could this have something to do with the WFS client caching
>> mechanism? But
>> if I look at your MAP file you don't specify the
>> wfs_request_method GET
>> metadata so if your Mapserver is new enough it should default
>> to POST, and
>> POST uses no cache at the moment.
>> How many GML files do you see coming into your IMAGEPATH
>> directory in the
>> first case you describe where all layers come from the same
>> WFS service?
>> Best regards,
>> Bart
>> On Tue, 29 Mar 2005 15:24:25 -0500, Godwin, Elizabeth
>> wrote:
>> > I'm experiencing a wierd phenomenon with a mapfile i am
>> working with.
>> > It's a bit of a unique case in that the map is composed of
>> 3 layers,
>> > all WFS layers coming from the same service. The odd thing
>> is...when I
>> > do this...  only the FIRST layer in the map is drawn, but using the
>> > class info from the LAST layer of this service.  If I draw
>> the middle
>> > layer from a different service...the same is true, except
>> that middle
>> > layer draws normal.  So FIRST is drawing with THIRD
>> styling, on top of
>> > SECOND that has it's own styling. In this case, it's
>> polygons, lines
>> > and points, so the polygons are drawing with point
>> symbology on top of
>> > lines.  Or if all are coming from the same service, all
>> that is drawn
>> > is polygins with point symbology. The last two layers are not drawn.
>> > I'm working with a cvs version from a month ago or so, but
>> I also tested
>> > against 4.4.0
>> > Shall I post a bug?  I'm asking first in case I've
>> overlooked something
>> > silly.
>> > Liz Godwin
>> Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
