Drawing the point on the map and adding it to shapefile
Till Adams adams at TERRESTRIS.DE
Thu Mar 31 07:56:21 EST 2005
Gambin Dejan wrote:
>Hi,
>Can someone show me an example of how to draw the point on the map and
>add it to the point shapefile (.shp) including the attribute data in
>associated .dbf file? I am using PHP/Mapscript
>I am also interested in possibility of moving the point to other
>location on the map and saving the changes in shapefile.
>Thanks very much
>Dejan Gambin
Dear Gambin,
we do this by using UMN as WMS and write the click-coordinate from a
featureinfo request back to a PostGIS database.
You are able to edit the attributes and upload images, etc.
If this helps, I can send you the code and a link to an example,
Till
Mit freundlichen Grüssen aus Bonn,
Till Adams
*     AmeiN! ArcGIS Map-Export-2-UMN     *
*      AmeiN! Workshop 11. Mai 2005      *
*        http://www.terrestris.de        *
Dipl. Geogr. Till Adams
terrestris, Paulsen&Adams GbR
Siemensstr. 8 * 53121 Bonn
Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
info at terrestris.de * www.terrestris.de
