Drawing the point on the map and adding it to shapefile
Camden Daily
cdaily at GMAIL.COM
Thu Mar 31 10:29:19 EST 2005
Here's some example code of how I create a shapefile from my database
information. It's probably not exactly what you need, but it'll give
you a good start. Note that if you want to interact with .dbf files
in PHP, you'll need to compile PHP with the --enable-dbase option.
In this snippet, I create a new shapefile and dbf file, but you could
probably just as easily open existing ones.
$shapefile = ms_newShapefileObj("fire_station", MS_SHP_POINT);
$dbffile = dbase_create("fire_station.dbf", array(array("NAME", "C",
50), array("ADDRESS", "C", 50)));
$sql = "SELECT DISTINCT fire_station.name, address.street_1,
address.longitude, address.latitude
FROM fire_station
JOIN address ON address_id=address.id";
$rs = $db->execute($sql);
foreach($rs as $result) {
$point = ms_newPointObj();
$point->setXY($result[2], $result[3]);
$shapefile->addPoint($point);
dbase_add_record($dbffile, array($result[0], $result[1]));
$shapefile->free();
