WMS GetMap not using Lat/Lonprojection
Frank Warmerdam fwarmerdam at GMAIL.COM
Wed May 4 11:23:27 EDT 2005
On 5/4/05, McGraw, Joanne <mcgrawj at agr.gc.ca> wrote:
> G'day, Frank,
> I tried your suggestion to use shp2img interactively to see if some clue
> is provided. One was, but I don't know what to do with it.
> When I tried:
> This was the result:
> msLoadMap(): Unknown identifier. (config):(12)
> The config line in my map is:
>     config      PROJ_LIB /usr/local/proj-4.4.5/nad/
> As far as I can tell, that's the correct syntax for config. Uppercase
> CONFIG makes no difference...I tried.
Joanne,
Is there any chance you did this with an older shp2img?  You
might want to check with "shp2img -v".  The CONFIG keyword
was new in 4.4.0 as far as I know, but the message seems to
suggest the config keyword isn't recognised.
Best regards,
