GIF Raster Image Process Problem {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Fri May 6 07:27:05 EDT 2005
Dear Akio,
The formula looks like:
X = Ax + By + C and Y = Dx + Ey + F (Affine transformation)
The order of the parameters in the world file is:
A
D
B
E
C
F
The process to find out the values of the parameters is called
georeferencing. There are a loft of programs what can solve the task
specifying point on the raster and giving the real co-ordinates for them.
Unfortunatelly I use commercial software for this purpose, but I think
GRASS can do it.
Usually more then the minimal 3 points are used with a least squares
estimation.
I hope it helps you
Zoltan
On Fri, 6 May 2005, Akio Neuchi wrote:
> Dear Zoltană
> Sorry for my late reply.
> We were in long holidays here in Japan.
> Thank you for your recommendations.
> In fact, by adjusting World file, the Raster/Vector Images finally so-so well superimposed,
> except the coordinates of these images are a bit dislocated, depend on the 1st and 4th pixel values on the World file.
> Though I am adjusting manually those numbers, what is the right formula to get the X and Y pixel dimensions?
> Thanks again for your help.
> Akio
> <World file>
> 0.000038
> 0.0000000000
> 0.0000000000
> -0.000038
> 139.738114
> 35.691990000000004
> MAP #file
> NAME rastest
> STATUS ON
> SIZE 600 700
> EXTENT 139.5 35.5 140 36
> UNITS dd
> SHAPEPATH "data"
> FONTSET "./fonts/fonts.lst"
> IMAGECOLOR 225 240 200
> IMAGETYPE GIF
> # Projection definition, set-upped by PROJ.4 parameters
> PROJECTION
> # "init=epsg:26915"
> "proj=latlong"
> END
> # Web interface definition (including WMS enabling metadata)
> WEB
> EMPTY "/gistest/empty.html"
> HEADER decide_route_header.html
> TEMPLATE decide_route.html
> FOOTER decide_route_footer.html
> MINSCALE 0
> MAXSCALE 300000000
> IMAGEPATH /var/opt/SUNWappserver7/domains/domain1/server1/docroot/gistest/tmp
> IMAGEURL /gistest/tmp
> LOG /var/opt/SUNWappserver7/domains/domain1/server1/docroot/gistest/rastest.log
> # TEMPLATE "decide_route.html"
> METADATA
> WMS_TITLE "MapDisplay Demo"
> WMS_ABSTRACT "Created by AN"
> WMS_ACCESSCONSTRAINTS none
> END
> END
> QUERYMAP
> SIZE 200 200
> STATUS ON
> STYLE HILITE
> COLOR 255 0 0
> END
> OUTPUTFORMAT
> NAME gif
> MIMETYPE "image/gif"
> DRIVER "GD/GIF"
> EXTENSION "gif"
> # IMAGEMODE RGB
> IMAGEMODE PC256
> TRANSPARENT FALSE
> # TRANSPARENT TRUE
> # FORMATOPTION "INTERLACE=OFF"
> END
> ### RASTER Layer
> LAYER
> NAME "RAS365313"
> GROUP "B_RASTER"
> TYPE RASTER
> DATA "MS12000DEF365313.gif"
> # STATUS ON
> STATUS DEFAULT
> TRANSPARENCY 100
> # OFFSITE 125 135 148
> PROJECTION
> "proj=latlong"
> # "init=epsg:26915"
> END
> PROCESSING "LOAD_WHOLE_IMAGE=TRUE"
> END
> # here starts Vector Layers
> # background - Parks
> LAYER
> NAME "BARA_PARK_AREA"
> GROUP "BARA_PARK"
> TILEINDEX "v_bak_ara_park"
> STATUS ON
> MAXSCALE 200000
> TYPE POLYGON
> PROJECTION
> # "init=epsg:26915"
> "proj=latlong"
> END
> CLASS
> BACKGROUNDCOLOR 0 220 0
> COLOR 150 200 100
> # COLOR 154 205 50
> END
> END
> # background - Sea surface
> LAYER
> NAME "BARA_SEA"
> TILEINDEX "v_bak_ara_sea"
> STATUS default
> TYPE POLYGON
> PROJECTION
> # "init=epsg:26915"
> "proj=latlong"
> END
> CLASS
> BACKGROUNDCOLOR 0 255 255
> COLOR 100 149 237
> END
> END
> # background - Rivers
> LAYER
> NAME "BLIN_RIVER"
> TILEINDEX "v_bak_lin_river"
> STATUS default
> MAXSCALE 200000
> TYPE LINE
> PROJECTION
> # "init=epsg:26915"
> "proj=latlong"
> END
> CLASS
> COLOR 100 149 237
> END
> END
> END # Map File
> -----Original Message-----
> From: Siki Zoltan [mailto:siki at agt.bme.hu]
> Sent: Friday, April 29, 2005 5:31 PM
> To: Akio Neuchi
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] GIF Raster Image Process Problem {Scanned}
> Dear Akio,
> You should define EXTENT, UNITS and SHAPEPATH at separate lines.
> Do you have world file to your image? Check the extents.
> Try STATUS DEFAULT.
> Bye Zoltan
