GIF Raster Image Process Problem {Scanned}
Akio Neuchi
neuchi at TCI-COM.BIZ
Fri May 6 00:07:21 EDT 2005
Dear Zoltan、
Sorry for my late reply.
We were in long holidays here in Japan.
Thank you for your recommendations.
In fact, by adjusting World file, the Raster/Vector Images finally so-so well superimposed,
except the coordinates of these images are a bit dislocated, depend on the 1st and 4th pixel values on the World file.
Though I am adjusting manually those numbers, what is the right formula to get the X and Y pixel dimensions?
Thanks again for your help.
Akio
<World file>
0.000038
0.0000000000
0.0000000000
-0.000038
139.738114
35.691990000000004
MAP #file
NAME rastest
STATUS ON
SIZE 600 700
EXTENT 139.5 35.5 140 36
UNITS dd
SHAPEPATH "data"
FONTSET "./fonts/fonts.lst"
IMAGECOLOR 225 240 200
IMAGETYPE GIF
# Projection definition, set-upped by PROJ.4 parameters
PROJECTION
# "init=epsg:26915"
"proj=latlong"
END
# Web interface definition (including WMS enabling metadata)
WEB
EMPTY "/gistest/empty.html"
HEADER decide_route_header.html
TEMPLATE decide_route.html
FOOTER decide_route_footer.html
MINSCALE 0
MAXSCALE 300000000
IMAGEPATH /var/opt/SUNWappserver7/domains/domain1/server1/docroot/gistest/tmp
IMAGEURL /gistest/tmp
LOG /var/opt/SUNWappserver7/domains/domain1/server1/docroot/gistest/rastest.log
# TEMPLATE "decide_route.html"
METADATA
WMS_TITLE "MapDisplay Demo"
WMS_ABSTRACT "Created by AN"
WMS_ACCESSCONSTRAINTS none
END
END
QUERYMAP
SIZE 200 200
STATUS ON
STYLE HILITE
COLOR 255 0 0
END
OUTPUTFORMAT
NAME gif
MIMETYPE "image/gif"
DRIVER "GD/GIF"
EXTENSION "gif"
# IMAGEMODE RGB
IMAGEMODE PC256
TRANSPARENT FALSE
# TRANSPARENT TRUE
# FORMATOPTION "INTERLACE=OFF"
END
### RASTER Layer
LAYER
NAME "RAS365313"
GROUP "B_RASTER"
TYPE RASTER
DATA "MS12000DEF365313.gif"
# STATUS ON
STATUS DEFAULT
TRANSPARENCY 100
# OFFSITE 125 135 148
PROJECTION
"proj=latlong"
# "init=epsg:26915"
END
PROCESSING "LOAD_WHOLE_IMAGE=TRUE"
END
# here starts Vector Layers
# background - Parks
LAYER
NAME "BARA_PARK_AREA"
GROUP "BARA_PARK"
TILEINDEX "v_bak_ara_park"
STATUS ON
MAXSCALE 200000
TYPE POLYGON
PROJECTION
# "init=epsg:26915"
"proj=latlong"
END
CLASS
BACKGROUNDCOLOR 0 220 0
COLOR 150 200 100
# COLOR 154 205 50
END
END
# background - Sea surface
LAYER
NAME "BARA_SEA"
TILEINDEX "v_bak_ara_sea"
STATUS default
TYPE POLYGON
PROJECTION
# "init=epsg:26915"
"proj=latlong"
END
CLASS
BACKGROUNDCOLOR 0 255 255
COLOR 100 149 237
END
END
# background - Rivers
LAYER
NAME "BLIN_RIVER"
TILEINDEX "v_bak_lin_river"
STATUS default
MAXSCALE 200000
TYPE LINE
PROJECTION
# "init=epsg:26915"
"proj=latlong"
END
CLASS
COLOR 100 149 237
END
END
END # Map File
-----Original Message-----
Sent: Friday, April 29, 2005 5:31 PM
To: Akio Neuchi
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] GIF Raster Image Process Problem {Scanned}
Dear Akio,
You should define EXTENT, UNITS and SHAPEPATH at separate lines.
Do you have world file to your image? Check the extents.
Try STATUS DEFAULT.
Bye Zoltan
