Possible Proxy Server problem
John Bonk
bonk at EOSDATA.GSFC.NASA.GOV
Fri May 6 16:18:36 EDT 2005
We have been having trouble getting our mapserver to retrieve data from
remote machines. I suspect the problem may be connecting through our proxy
server.
We have specified our proxy server in a .dodsrc file, and we have been able
to retreive data from a dods server. But we still can't retrieve files
from wms servers.
Is there something special that has to be done to tell mapserv to go
through a proxy when retrieving data from a wms server?
The map file is below. It works on another machine that does not have a
proxy server.
Any help will be appreciated,
John
MAP
IMAGETYPE PNG
EXTENT -117.263 30.168 -83.774 51.676
units DD
DEBUG ON
SIZE 400 300
SHAPEPATH "data"
PROJECTION
"init=epsg:4326"
END
CONFIG PROJ_LIB /usr/local/share/proj/
WEB
IMAGEPATH '/local/tools/gdaac/TS2/www/workshop/tmp/'
IMAGEURL '/TS2/workshop/tmp/'
LOG '/local/tools/gdaac/TS2/www/workshop/debug.log'
METADATA
"wms_title" "WMS Test Demo"
"wms_onlineresource"
"http://g0dup05u.ecs.nasa.gov/TS2/cgi-bin/mapserv?"
"wms_abstract" "Test for mapserver"
"ows_schemas_location" "http://ogc.dmsolutions.ca"
END
END
# Start of scalebar
SCALEBAR
IMAGECOLOR 255 50 5
LABEL
COLOR 55 55 55
SIZE tiny
END
STYLE 1
SIZE 100 2
COLOR 0 0 0
UNITS MILES
INTERVALS 2
TRANSPARENT TRUE
STATUS EMBED
END
LAYER
NAME RTOPO
TYPE RASTER
units DD
OFFSITE 0 0 0
DEBUG ON
STATUS DEFAULT
PROJECTION
"init=epsg:4326"
END
CONNECTIONTYPE WMS
CONNECTION "http://globe.digitalearth.gov/viz-bin/wmt.cgi?"
METADATA
"wms_request" "GetMap"
"wms_name" "RTOPO"
"wms_server_version" "1.1.1"
"wms_srs" "EPSG:4326"
"wms_format" "image/png"
END
END
LAYER # MODIS raster layer begins here
METADATA
"wms_title" "test layer"
END
DEBUG ON
NAME modis
DATA RGB_mosaic_250m.tif
EXTENT -13053641.300000 3358256.867 -9325729.471 5752577.812
PROJECTION
"proj=eqc"
"lat_ts=0.0"
"x_0=0.0"
"y_0=0.0"
END
STATUS ON
TYPE RASTER
END # MODIS raster layer ends here
LAYER # States line layer begins here
METADATA
"wms_title" "test states layer"
END
DEBUG ON
NAME states
TYPE POLYGON
STATUS ON
DATA "statesp020"
PROJECTION
"proj=latlong"
"ellps=GRS80"
"datum=NAD83"
END
CLASS
NAME "states"
OUTLINECOLOR 60 60 60
SYMBOL 0
END
END # States line layer ends here
END # end of map file.
John Bonk
SSAI/NASA GES DISC
Phone:(301) 614-5280
Fax: (301) 614-5268
For more information about
the NASA GES DISC and its services:
http://daac.gsfc.nasa.gov/
