queryByShape on PostGIS-Layer segfault in php-mapscript
Uwe Junge
ujunge at PMCENTRAL.COM
Sat May 7 08:54:50 EDT 2005
Hi Bart,
i just copied the dll's and tested queryByShape
It works !!!
Thank you so much for your support.
I really appreciate the manner, how You spend personal time and efforts
to help out. Hopefully i have some time in the future to contribute my
knowledge to the list
as well.
Uwe
Bart van den Eijnden wrote:
> Hi Uwe,
> I am attaching the binaries as a zip to this e-mail.
> Please note that the php mapscript extension is dependent on
> libmap.dll, this is different from the builds from maptools.org. Make
> sure php can find all the dll's.
> Let me know how it goes.
> Best regards,
> Bart
> On Sat, 07 May 2005 13:30:11 +0200, Uwe Junge <ujunge at pmcentral.com>
> wrote:
>> Bart,
>> that would be great !
>> the make i have is from mapserver-4.4.2-win32-php4.3.11.zip:
>> MapServer version 4.4.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>> OUTPUT=WBMP OUTPUT=PDF
>> OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
>> SUPPORTS=WMS_CLI
>> ENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
>> INPUT=EPPL7 INPU
>> T=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>> Thank you very much again
>> Uwe
>>> Hi Uwe,
>>> I can send you a test binary off-list. If the problem still occurs,
>>> it would be wise to report a bug so hopefully the fix will make it
>>> into 4.6 final.
>>> Best regards,
>>> Bart
>>> On Sat, 07 May 2005 12:43:06 +0200, Uwe Junge
>>> <ujunge at pmcentral.com> wrote:
>>>> Thank You very much Bart.
>>>> Unfortunatly, I rely at this time completely on the binary package
>>>> made available
>>>> at maptools.org; the latest version there is
>>>> mapserver-4.5-win32-php4.3.7.zip
>>>> built on March-15. So let's wait ...
>>>> The function to do queries-by-shape are essential to our application.
>>>> Yesterday, I tried PostGis 1.0.0 and was really pleased (see
>>>> further down) .
>>>> Currently, all the data, including dynamically generated data,
>>>> are sourced as shapefiles
>>>> in a multi-server arrangement. The overhead to distribute
>>>> dynamically generated data to serveral servers is quit
>>>> significant at this time.
>>>> Of course, additional functionality can be developed around the
>>>> application
>>>> when using PostGis as an additional source, in partiular when it comes
>>>> - to large Attribut-Datasets (for example Census SF1 & SF3 with
>>>> about 16K Attributes) that needs to be sourced for thematic maps,
>>>> - or when using serveral mapservers in parallel with dynamic
>>>> content stored on one single PostGis-Server.
>>>> Developing a separate, scripted direct search on PostGis on the
>>>> back-end is not an option,
>>>> since the overhead to append the results one-by-one to the
>>>> mapserver-query-result-set (*.qyr), on which the application
>>>> relies, is way to much.
>>>> Just for interest, let me summarize my experience with mapserver:
>>>> I made several attempts to build php_mapscript.dll from the
>>>> sources with ms vc, together with
>>>> postgres/postgis on cygwin, spend a lot of time and never got it
>>>> working.
>>>> So i focus on application development instead an use the binary
>>>> packages for the installations.
>>>> Fortunatly, i found yesterday the brand new installers for
>>>> postgres 80 and postgis;
>>>> - it took me 4 hours to install, to write a script and to import
>>>> 1Gig worth of Tiger-shape files and
>>>> geocoded database content.
>>>> I'm **very** pleased about the speed of mapserver in conjunction
>>>> with postgis,
>>>> there is only a relatively small rendering-time difference
>>>> (varying between 0..30%)
>>>> for the colocated, postgres server out-of-the-box compared to
>>>> reading the indexed shape files (tiles) directly !
>>>> The PostGis-Team did a great job with their new Version 1.0.0.
>>>> Also, i'm **very** pleased about the very small foot-print of
>>>> php_mapscript compared to other
>>>> GIS-servers. Map-File and Layer-Managment are anyway custom, so
>>>> these additional
>>>> capabilities of 'competing products' are of no use (for us) anyway.
>>>> To my surprise, rendering time (ca 30 Gig of mapdata browsed) on my
>>>> new
>>>> notebook (mobile Athlon 3700+,1Gig Ram with a 7.200 rpm HD on USB2.0)
>>>> was significantly faster compared to development- or the
>>>> production server
>>>> (Dual Xeon 2.4-2.8GHz, 4Gig RAM, SCSI Raid10 15K rpm HD) !!!!!!
>>>> Of course I know when more user simultaniously access the
>>>> services, this situation will change.
>>>> But the lesson learned for mapserver is to spend the money for
>>>> the processors and not for the disks.
>>>> Last year we also made an attempt to to use Linux (32bit) for the
>>>> mapservers, apart from getting
>>>> php_mapscript working, rendering was significantly slower compared
>>>> to W2K on the same hardware.
>>>> But that should change when using 64bit versions and hardware.
>>>> Uwe Junge
>>>> CTO PMCentral Systems, Inc.
>>>> 4201 Pinefield Court
>>>> Fairfax, VA 22033
