WCS sampling error
Frank Warmerdam fwarmerdam at GMAIL.COM
Thu May 12 10:32:38 EDT 2005
On 5/12/05, Norman Barker <nbarker at rsinc.com> wrote:
> Hi,
> I am using the WCS to serve geotiff files, it seems that if the values of RESX and RESY are not equal to the base
> resolution of the tiff image in the getCoverage request then the request fails with a black image being returned to the
> user.
> So, if resx, resy are 1.125 say then it works fine, but then another file having a resolution value of 1.21211211.. reported by the geotiff file (so resolution to a few more than 2 decimal places) causes the resampling to occur and the image to be blank.
> Do I have to truncate my values of resx, resy when I export to geotiff to put the files in the WCS?  This resampling will
> happen when I make other requests, will it also fail (I remember making reprojection requests with DEMs and this happened),
> any advice would be appreciated.
Norman,
I think this is the same as the following bug, which I have been meaning
to revisit.  your note gives me a big clue as to what is going wrong.
  http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1183
Best regards,
