WCS sampling error
Norman Barker
nbarker at RSINC.COM
Thu May 12 12:44:14 EDT 2005
-----Original Message-----
From: Frank Warmerdam [mailto:fwarmerdam at gmail.com]
Sent: Thursday, May 12, 2005 3:33 PM
To: Norman Barker
Cc: MAPSERVER-USERS at lists.umn.edu
Subject: Re: [UMN_MAPSERVER-USERS] WCS sampling error
On 5/12/05, Norman Barker <nbarker at rsinc.com> wrote:
> Hi,
> I am using the WCS to serve geotiff files, it seems that if the values of RESX and RESY are not equal to the base
> resolution of the tiff image in the getCoverage request then the request fails with a black image being returned to the
> user.
> So, if resx, resy are 1.125 say then it works fine, but then another file having a resolution value of 1.21211211.. reported by the geotiff file (so resolution to a few more than 2 decimal places) causes the resampling to occur and the image to be blank.
> Do I have to truncate my values of resx, resy when I export to geotiff to put the files in the WCS? This resampling will
> happen when I make other requests, will it also fail (I remember making reprojection requests with DEMs and this happened),
> any advice would be appreciated.
Norman,
I think this is the same as the following bug, which I have been meaning
to revisit. your note gives me a big clue as to what is going wrong.
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1183
Best regards,
Hi Frank,
thanks for the reply, is there any work around for this at the moment, or can you give me an indication of how we could fix it? I will fix my files to have a fixed number of decimal points but
eventually it would be cool to be able to make requests at different resolutions.
Many thanks,
Norman Barker
