Image transparency via SWIG API
Sean Gillies sgillies at FRII.COM
Mon May 16 16:02:35 EDT 2005
On May 16, 2005, at 10:01 AM, Rick Innis wrote:
> I'm writing an application which loads a point layer from a Postgis
> table and displays little flag icons at the relevant points.
> I haven't been able to work out how to get MapServer to respect the
> transparency of the images. The flags appear surrounded by a white
> square.
> If I load the same layer via a mapfile, everything works fine - the
> images are displayed without the white square.
> Would appreciate any insight anyone has on what might be going on.
> FWIW, I'm working with MapServer 4.4.1, Postgres 8.0.1, PostGIS RC6,
> and the Java API bindings.
> Thanks,
>         --Rick.
Rick, you say everything works fine when you load the same layer via a
mapfile ... so why not do that?  I'm going to need more details on your
use before I can be of any help such as how you are styling and
rendering the points, and perhaps the relevant portion of the mapfile
that works.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://zcologia.com
