How can I highlight more than one feature in QUERY mode?
Fischer, Brian
bfischer at HOUSTONENGINEERINGINC.COM
Mon May 23 13:24:53 EDT 2005
I don't know how your application is setup, but another option is to
create a dummy layer in your map file to use for highlighting a feature.
LAYER # Dummy Parcels Polygon Layer to Highlight it yellow
NAME parcel_poly
DATA Parcels
MAXSCALE 200000
STATUS DEFAULT
TYPE LINE
CLASSITEM 'PIN'
CLASS
NAME "Parcel Selected"
EXPRESSION '%PIN%'
COLOR 255 255 0
SYMBOL 'circle'
SIZE 4
END
END # Dummy Parcels Polygon Layer to Highlight it yellow
Then use some javascript in your web page to create an expression and
pass the variable to the CGI (example
"/cgi-bin/mapserv.exe?mode=map&PIN=pin=17000003443001%20or%20pin=1700000
345494") and it will substitute the PIN variable name in the mapfile
with the value you passed in with the call to the CGI. The expression
can contain "and" and "or" in it.
This is explained a bit in
http://mapserver.gis.umn.edu/doc44/mapfile-reference.html#variablesubsti
tution documentation.
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Fawcett, David
Sent: Monday, May 23, 2005 12:04 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] How can I highlight more than one
Should that be ITEMNQUERYMAP?
David Fawcett
Minnesota Office of Environmental Assistance
david.fawcett at moea.state.mn.us
651.215.0200
-----Original Message-----
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On Behalf Of Daniele Margotti
Sent: Saturday, May 21, 2005 3:51 AM
Subject: [UMN_MAPSERVER-USERS] How can I highlight more than one
Hi list,
with CGI mode=ITEMQUERYMAP I can produce a map with one
highlighted feature (defined using QITEM, QLAYER and QSTRING).
How can I highlight more than one feature (within the same
layer) using the same syntax (QITEM + QLAYER + QSTRING)?
Is there the possibility to use an "OR condition" or a regular
expression in QSTRING parameter?
Thank you,
Daniele
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050523/0ea14d28/attachment.html
