mapserv.exe
Lluís Garcia i Mestres
lluisgm at GMAIL.COM
Wed May 25 03:49:07 EDT 2005
Thanks, it works now
2005/5/25, Bart van den Eijnden <BEN at syncera-itsolutions.nl>:
> Try putting your IP address into the IMAGEURL.
> eg if your IP address is 192.168.3.27 <http://192.168.3.27>:
> IMAGEURL "http://192.168.3.27/mapserver/tmp/"
> Best regards,
> Bart
> Syncera-ITSolutions
> Postbus 270
> 2600 AG DELFT
> tel.nr <http://tel.nr>.: 015-7512436
> email: BEN at Syncera-ITSolutions.nl
> >>> Lluís Garcia i Mestres <lluisgm at gmail.com> 05/25/05 09:31am >>>
> Hi,
> I have this in my web object.
> IMAGEPATH "c:\archivos de programa\apache
> group\apache2\htdocs\mapserver\tmp\"
> IMAGEURL "http://[localhost]\mapserver\tmp\"
> And in the template there are something suspicious:
> Just the sclae function works
> <TD align=middle>Escala 1:<SCRIPT language=JavaScript>document.write
> (trunca([scale]));</SCRIPT>
> and the others not...
> <td align="left">
> <img src="[scalebar]" alt="Scale bar" align="middle">
> <img src="[legend]" alt="Scale bar" align="middle"><br>
> > What value do you have for IMAGEURL in your WEB object?
> > Does it reference localhost?
> > Best regards,
> > Bart
> > Syncera-ITSolutions
> > Postbus 270
> > 2600 AG DELFT
> > tel.nr <http://tel.nr> <http://tel.nr>.: 015-7512436
> > >>> Lluís Garcia i Mestres <lluisgm at GMAIL.COM> 05/25/05 09:12am >>>
> > Hi list,
> > I'm working with mapserver 4.4.1 in mandrake 10.1 and it works fine. Now
> > I'm triing to run it under windows. In my localhost the map is
> displayed,
> > but if I try to display from another computer the template appears but
> the
> > there are no map, legend, scaler and reference. It looks like the
> > mapserver.exe doesn't work. My mapserv.exe is in the cgi-bin directory
> of
> > apache and if it's ok for my localhost it should work also from others
> > computers. Any suggestion?
> > thanks
> > Lluís Garcia i Mestres,
> > lluisgm at hotmail.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050525/56deedd7/attachment.html
