joining shp and dbase files
Alberto Gomez
agomez at CCCMM.CESGA.ES
Thu May 26 07:30:45 EDT 2005
Hi Emil,
Thank you for your quick response. It works great!!... but in local. I'm
working in windows and my dbf file is located in a network volume (Z:). I
set DATA parameter with a full path like this:
"/inetpub/wwwroot/project/data/myfile.dbf" and i need to change from "C:"
to
"Z:".
Could you helpme with that?
Tanks in advance,
Alberto
> ----- Original Message -----
> From: "Emil Zegers" <taatuut at PLANET.NL>
> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Thursday, May 26, 2005 9:12 AM
> Subject: Re: [UMN_MAPSERVER-USERS] joining shp and dbase files
> > Hello Alberto,
> > You cannot use the MapServer JOIN to classify and display attributes
from
> > the join table (see bug
> > http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=674).
> > So the JOIN function for a LAYER has not disappeared but is not suited
for
> > this purpose.
> > You could try using OGR JOIN however.
> > OGR SQL supports a limited form of one to one JOIN.
> > Somehting like:
> > CONNECTIONTYPE OGR
> > CONNECTION "data/popplace_pt"
> > DATA "SELECT columns FROM table LEFT JOIN some join statement"
> > Take a look at the JOIN examples at
> > http://www.remotesensing.org/gdal/ogr/ogr_sql.html
> > Regards,
> > Emil
> > -----Original Message-----
> > From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
> > Behalf Of Alberto Gomez
> > Sent: donderdag 26 mei 2005 9:01
> > To: MAPSERVER-USERS at LISTS.UMN.EDU
> > Subject: [UMN_MAPSERVER-USERS] joining shp and dbase files
> > Hello list,
> > I'm using mapserver as cgi and I need to do a color classification by a
> > field in the dbase table, so that I can see any modification in this
table
> > at real time in my map server.
> > I've tried to do a join between my shapefile and dbase table but the
layer
> > disappeared. All that I've read is that Join function in mapfile is no
> > longer available. Is there any other way to do this? Can you post an
> > example?
> > Thanks in advance.
