joining shp and dbase files
Emil Zegers taatuut at PLANET.NL
Thu May 26 07:42:45 EDT 2005
Hello Alberto,
You could try switching to absolute path names.
If your dbf is located at C:/inetpub/wwwroot/project/data/myfile.dbf
Then instead of:
"/inetpub/wwwroot/project/data/myfile.dbf"
in the DATA parameter use:
"C:/inetpub/wwwroot/project/data/myfile.dbf"
Similair if the file is located at Z:/geodata/dbase/myfile.dbf
"Z:/geodata/dbase/myfile.dbf"
UNC paths also works so if your Z: disk is a mapping to a machine called
alberto then use
"\\alberto\geodata\dbase\myfile.dbf"
Make sure the Windows user has appropriate rights to access the disk or
share and don't forget that Windows IIS uses the IUSR on default.
The IUSR account is a local machine account so it can only access local
files and not mapped drives or other servers.
So if you want to access data on other servers you need to switch to use a
domain user in IIS (best is to create a new user or group for this purpose).
Accessing other drives/servers may work if you use integrated security in
addition to anonymous access on IIS but this is only so if your (domain)
accoutn has sufficient rights. Everybody from outside (not a domain user)
will not be able to access that data. This can be confusing when testing
your setup.
Regards,
Emil
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Alberto Gomez
Sent: donderdag 26 mei 2005 13:31
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] joining shp and dbase files
 Hi Emil,
   Thank you for your quick response. It works great!!... but in local. I'm
 working in windows and my dbf file is located in a network volume (Z:). I
 set DATA parameter with a full path like this:
 "/inetpub/wwwroot/project/data/myfile.dbf" and i need to change from "C:"
to
 "Z:".
   Could you helpme with that?
   Tanks in advance,
    Alberto
