RASTER Layer.
Owens, Ryan J NWD02 CONTRACTOR
Ryan.J.Owens at NWO02.USACE.ARMY.MIL
Tue May 31 08:00:09 EDT 2005
Ed,
This is a bit overdue... but thanks for your assistance with my question. I
was able to get the raster layer to function properly.
Another question... do spaces in a map file cause problems? In other words,
am I creating problems when I am trying to make a map file more readable by
realigning code and adding spaces?
Ryan
Sent: Tuesday, May 24, 2005 2:16 PM
To: Owens, Ryan J NWD02 CONTRACTOR; MAPSERVER-USERS at LISTS.UMN.EDU
Subject: RE: [UMN_MAPSERVER-USERS] RASTER Layer.
Ryan -
The example MAP file you give seems (at a quick look) OK if all your input
data is in the same projection. The only way you know what projections to
use is by knowing your source data. Some source formats, like GeoTIFF, will
have projection information embedded in them. Others, like your shapefiles,
usually do not - you need to know what you have.
Do you think all your data is in the same projection? What does the listgeo
command tell you when you use it to dump the metadata from the basin_alb.tif
file?
I'm going to guess that your raster image is in the Albers or other
projection, and your shapefiles are in unprojected geographic coordinates.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Owens, Ryan J NWD02 CONTRACTOR
Sent: Tuesday, May 24, 2005 2:45 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] RASTER Layer.
Hello Listserv,
I'm new to Map Server and I am having some difficulties with getting a raster
output to work. So far I have been able to get a TYPE LINE output to work.
I want to add another layer, a RASTER layer, but it does not work and I don't
know what I am doing wrong. Will someone scan my code to see if I have done
something incorrectly? I am outputting my data to a Flash viewer in a HTML
template.
Thank you,
Ryan
MAP
NAME FMV_
EXTENT -544000 89800 1393000 1254000
WEB
log "./test.log"
TEMPLATE "test_template.html"
IMAGEPATH "./tmp/"
IMAGEURL "http://[my domain]/fmv/test/tmp/"
END
DEBUG ON
OUTPUTFORMAT
NAME swf
DRIVER "SWF"
MIMETYPE "application/x-shockwave-flash"
EXTENSION "swf"
IMAGEMODE PC256
FORMATOPTION "OUTPUT_MOVIE=MULTIPLE"
END
IMAGETYPE swf
SIZE 460 500
SHAPEPATH "data"
IMAGECOLOR 255 255 255
PROJECTION
# "proj=laea"
# "ellps=clrk66"
# "lat_0=45"
# "lon_0=-100"
# Alternatively, you can specify an EPSG code.
# "init=epsg:2163"
END
# Start of LAYER DEFINITIONS ---------------------------------------------
LAYER
NAME "basin"
DATA "data/basin_alb.tif"
STATUS DEFAULT
TYPE RASTER
PROCESSING "BANDS=1,2,3"
OFFSITE 71 74 65
# PROJECTION
# END
END
LAYER
NAME "river"
DATA missouri_river
STATUS DEFAULT
TYPE LINE
METADATA
"SWFDUMPATTRIBUTES" "NAME,LENGTH"
END
CLASS
COLOR 0 0 254
END
END
LAYER
NAME dcp
DATA dcps
STATUS DEFAULT
TYPE POINT
METADATA
"SWFDUMPATTRIBUTES" "MRADS_ID"
END
CLASS
SYMBOL 0
COLOR 0 0 254
END
END
# End of LAYER DEFINITIONS -------------------------------
END # end of map file/object^M
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050531/eb299ef5/attachment.html
