MapServer 4.6.0-beta3 released
    Yewondwossen Assefa
    assefa at DMSOLUTIONS.CA
    Tue May 31 07:04:40 PDT 2005
I will put one in a couple of hours on mapools.org and send an e-mail on
this.
Later
Bart van den Eijnden wrote:
> Daniel,
> will there be new Windows binaries on maptools.org?
> Or do people need to compile their own since the release cycles are so short?
> Best regards,
> Bart
> Syncera-ITSolutions
> Postbus 270
> 2600 AG  DELFT
> tel.nr.: 015-7512436
> email: BEN at Syncera-ITSolutions.nl
>>>>Daniel Morissette <dmorissette at DMSOLUTIONS.CA> 05/31/05 12:32am >>>
> MapServer 4.6.0-beta3 is now available for download on the MapServer
> website (http://mapserver.gis.umn.edu/dload.html). This should be the
> last beta before the release candidate (early next week) and the final
> release just in time for MUM3. Once again, we invite experienced users
> to contribute to the release process by testing the betas with their
> applications and reporting any issues via bugzilla.
> The list of fixes since beta2 is included below.
> Daniel
>   Daniel Morissette               dmorissette at dmsolutions.ca
>   DM Solutions Group              http://www.dmsolutions.ca/
> Version 4.6.0-beta3 (2005-05-27)
> - Bug 1298 : enable Attribution element in wms Capabilities XML
> - Bug 1354: Added a regex wrapper, allowing MapServer to build with PHP
>    compiled with its builtin regex
> - Bug 1364: HTML legend templates: support [if] tests on "group_name" in
>    leg_group_html blocks, and for "class_name" in leg_class_html blocks.
> - Bug 1149: From WMS 1.1.1, SRS are given in individual tags in root Layer
>    element.
> - First pass at properly handling XML exceptions from CONNECTIONTYPE WMS
>    layers. Still needs some work. (bug 1246)
> - map.h/mapdraw.c: removed MAX/MIN macros in favour of MS_MAX/MS_MIN.
> - Bug 1341, 1342 : Parse the unit parameter for DWithin filter request.
>    Set the layer tolerance and toleranceunit with paramaters parsed.
> - Bug 1277 : Support of multiple logical operators in Filter Encoding.
> - mapwcs.c: If msDrawRasterLayerLow() fails, ensure that the error message
>    is posted as a WCS exception.
> - Added experimental support for "labelcache_map_edge_buffer" metadata to
>    define a buffer area with no labels around the edge of a map (bug 1353)
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
More information about the MapServer-users
