MapServer 4.6.0-beta3 released
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Tue May 31 11:45:13 EDT 2005
Bart,
Maptools.org has been updated with the beta3 binaries.
Later,
PS : I will definitely add a php5.0.4 support when the 4.6 is realeased.
Yewondwossen Assefa wrote:
> I will put one in a couple of hours on mapools.org and send an e-mail on
> this.
> Later
> Bart van den Eijnden wrote:
>> Daniel,
>> will there be new Windows binaries on maptools.org?
>> Or do people need to compile their own since the release cycles are so
>> short?
>> Best regards,
>> Bart
>> Syncera-ITSolutions
>> Postbus 270
>> 2600 AG DELFT
>> tel.nr.: 015-7512436
>> email: BEN at Syncera-ITSolutions.nl
>>>>> Daniel Morissette <dmorissette at DMSOLUTIONS.CA> 05/31/05 12:32am >>>
>> MapServer 4.6.0-beta3 is now available for download on the MapServer
>> website (http://mapserver.gis.umn.edu/dload.html). This should be the
>> last beta before the release candidate (early next week) and the final
>> release just in time for MUM3. Once again, we invite experienced users
>> to contribute to the release process by testing the betas with their
>> applications and reporting any issues via bugzilla.
>> The list of fixes since beta2 is included below.
>> Daniel
>> Daniel Morissette dmorissette at dmsolutions.ca DM
>> Solutions Group http://www.dmsolutions.ca/
>> Version 4.6.0-beta3 (2005-05-27)
>> - Bug 1298 : enable Attribution element in wms Capabilities XML
>> - Bug 1354: Added a regex wrapper, allowing MapServer to build with PHP
>> compiled with its builtin regex
>> - Bug 1364: HTML legend templates: support [if] tests on "group_name" in
>> leg_group_html blocks, and for "class_name" in leg_class_html blocks.
>> - Bug 1149: From WMS 1.1.1, SRS are given in individual tags in root
>> Layer
>> element.
>> - First pass at properly handling XML exceptions from CONNECTIONTYPE WMS
>> layers. Still needs some work. (bug 1246)
>> - map.h/mapdraw.c: removed MAX/MIN macros in favour of MS_MAX/MS_MIN.
>> - Bug 1341, 1342 : Parse the unit parameter for DWithin filter request.
>> Set the layer tolerance and toleranceunit with paramaters parsed.
>> - Bug 1277 : Support of multiple logical operators in Filter Encoding.
>> - mapwcs.c: If msDrawRasterLayerLow() fails, ensure that the error
>> message
>> is posted as a WCS exception.
>> - Added experimental support for "labelcache_map_edge_buffer" metadata to
>> define a buffer area with no labels around the edge of a map (bug
>> 1353)
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
