MapServer 4.6.0-beta3 released
Ken Lord kenlord at GMAIL.COM
Tue May 31 13:32:15 EDT 2005
I don't know if this is a bug or a feature, but the move from 4.6beta2 to
4.6beta3 has disabled the use of the parameter "TRANSPARENT ON/OFF" within
OUTPUTFORMAT.
 Just a reminder for the 4.6 documentation that still lists the parameter.
 Thanks,
Ken Lord
Vancouver BC
 On 5/31/05, Joshua Buysse <buysse at socsci.umn.edu> wrote:
> > The list of fixes since beta2 is included below.
> > - Bug 1354: Added a regex wrapper, allowing MapServer to build with PHP
> > compiled with its builtin regex
> Whatever changed here, my problems building mapserver with PHP
> Mapscript on Redhat Enterprise 4 are now resolved. Before this change,
> whenever I built with PHP support, all variants would core dump loading
> a mapfile (CGI, Python, PHP, etc.).
> I have been working to build mapserver as a clean RPM with Redhat's PHP
> and Postgres packages, so that only minimal changes from the base OS
> need to be made. I made a slight modification to the PHP packages to
> install the regex object files in /usr/include/php/regex (with the
> include files), and built a few support packages.
> Almost all of the packages that I've used are based on the
> mappinghacks.com <http://mappinghacks.com> packages, and I'm releasing my
> modified versions here:
> http://www.socsci.umn.edu/~buysse/mapserver/
> If anyone's interested in them, I'm going to be maintaining versions of
> these packages for RHEL 4.
> Josh Buysse, System Administrator
> CLA-OIT, Division of Research Computing Services
> University of Minnesota
> "Democracy should not be for export only."
> -- Jesse Jackson
> http://www.suntimes.com/output/jesse/cst-edt-jesse30.html
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050531/ae222f8d/attachment.html
