PerlMapScript Testers Needed NOW
Sean Gillies
sgillies at FRII.COM
Tue May 31 18:06:09 EDT 2005
On May 31, 2005, at 3:23 PM, Lowell Filak wrote:
> Hello all,
> The SWIG typemap for imageObj->write is ready for testing at:
> http://www.highwayengineer.co.medina.oh.us/temp/mapscript.tar.gz
> There are 3 files included:
> medina1.patch - the patch file containing the code changes.
> medina1_autogen.patch - the patch file containing changes to the SWIG
> output if you don't feel like re-SWIG'ing yourself.
> nonwrite.cgi - sample code for using the 'write' method in both GD:: &
> Image::Magick.
> Requirements:
> Mapserver & MapScript 4.4.2.
> Perl 5.8.0 + (this uses PerlIO vs. stdio).
> Thanks go to the Steve Lime, MS-team(et. al.), Sean Gillies, & Chip
> Salzenberg.
> Lowell
> P.S. The changes for map->processXTemplate are also included but I have
> not tested those yet.
Well, better late than never ;) Create a bug in our bugzilla and let's
get this done. Better if this is tested against MapServer 4.6 beta 3 if
y'all want this in the next big release.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://zcologia.com
