Debug-Hints with Tomcat
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Wed Nov 2 06:29:05 EST 2005
Newer glibc have internal checks that are probably turned on by
default on some distros.
Try to play with the MALLOC_CHECK_ variable and read this (it is about
fedora core, but should apply to suse too):
glibc
The version of glibc provided with Fedora Core 3 performs
additional internal sanity checks to prevent and detect data
corruption as early as possible. By default, should corruption
be detected, a message similar to the following will be displayed
on standard error (or logged via syslog if stderr is not open):
*** glibc detected *** double free or corruption: 0x0937d008 ***
By default, the program that generated this error will also be
killed; however, this (and whether or not an error message is
generated) can be controlled via the MALLOC_CHECK_ environment
variable. The following settings are supported:
0 -- Do not generate an error message, and do not kill the program
1 -- Generate an error message, but do not kill the program
2 -- Do not generate an error message, but kill the program
3 -- Generate an error message and kill the program
Note
If MALLOC_CHECK_ is explicitly set a value other than 0, this
causes glibc to perform more tests that are more extensive than
the default, and may impact performance.
Should you have a program from a third party ISV that triggers
these corruption checks and displays a message, you should
file a defect report with the application's vendor, since this
indicates a serious bug.
Best regards,
Umberto
On 11/2/05, Benedikt Rothe <umn-ms at hydrotec.de> wrote:
> Dear Mapserver-Users
> We developed a Tomcat/Mapserver-Site using Mapscript on
> Linux/SUSE 9.3.
> Many things run fine. On a test-machine we made successfully
> some stress-testing and Tomcat runs for weeks.
> Unfortunately Tomcat crashes on the customers production-machine
> approximately once a day. It runs for several hours,
> passes stress-tests successfully but crashes unpredictable after
> 12-20hours.
> The crash occurs in Mapserver-Code. Message in the Tomcat-log
> is
> *** glibc detected *** double free or corruption (top): 0x0xf99950"
> Question: Can I do something to make this error-message more helpful?
> I'd like to have the stack and the line-numbers in the sourcecode.
> (I mean the C-stack and C-linenumber and not the Java-Stack...)
> I looked through the gcc-man-page, but I coudn't find anything helpful.
> Thanks
> Benedikt Rothe
