Changing layer templates on the fly
Xin crazygecko at GMAIL.COM
Wed Nov 2 06:36:09 EST 2005
I'm using MapServer 2.6 via CGI, it's working really well. After reading
about changing attributes on-the-fly via CGI parameters I've been hooked on
it. Changing everything from layer tolerance (map_mylayer_tolerance=10) to
templates (map_mylayer_template=file.html). But for the life of me, I can't
figure out how to change header templates! It simply doesn't work.
I've tried searching in the mailing list, but there is nothing.
map_mylayer_header=header.html just doesn't work. Specifying the header
attribute in the mapfile works file, but I'd rather change it dynamically. I
realise the layer portion is case-sensitive, so that's not the problem.
Your help is greatly appreciated.
Xin
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051102/864cc0e5/attachment.html
