Merge several layers into a single multi-layer GetMap request
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Thu Nov 3 11:20:11 EST 2005
Hi There,
I am nopt sure why would this happen. Cheking the code, the criteria
for merging is the following (mapwmlalayer.c around line 927) :
if (!bForceSeparateRequest &&
lastconnectiontype == MS_WMS &&
psLastWMSParams != NULL &&
sThisWMSParams.numparams == psLastWMSParams->numparams &&
strcmp(sThisWMSParams.onlineresource,
psLastWMSParams->onlineresource) == 0)
which translates into :
- no metadata set force_separate_request
- number of parameters are the same between 2 requests
(parameters being all the manadatory and non manadory request parameters)
- the onlineresource should be the same.
Adding a wmss_sld_body would only end up adding one paramater. If all
your consececutive layers follow these criterias, It shoudl merge.
Thinking about It and reading the doc, I am not sure why the number of
parameters is added into the test.
Later,
J. Parapar wrote:
> Hi all
> We have several wms layers with the same wms server in our mapfile
> client and MapServer is making one GetMap request for each of the
> layers. All the layers have the parameter wms_sld_body set to AUTO. In
> some tests with layers without SLD MapServer do merges several layers
> into a single multi-layer GetMap request. Does this optimization only
> works with non SLD layers?
> Thanks in advance,
> Jorge
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
